Easy operations but somehow I'm wrong
  • Thread starter Thread starter fallen186
    Operations
The discussion revolves around a calculation involving experimental results, specifically the operation (7.8 m - 0.34 m) / (1.15 s + 0.82 s). The initial calculation yields 3.79 m/s, but the correct answer is stated to be 0.76 m/s, indicating a misunderstanding of the question. It is clarified that the second number represents uncertainty, suggesting the calculation should focus on 7.8 m / 1.15 s instead. Participants emphasize the importance of significant figures and uncertainty in reporting the final answer.
fallen186
Carry out these operations as if they were calculations of experimental results, and express each answer in the correct units and with the correct number of significant figures:
(d) (7.8 m - 0.34 m) / (1.15s + 0.82 s)
V=d/t
(7.46 m) / (1.97 s)
3.79 m/s
It tells me the answer is 0.76 m/s :\. I double checked and this is what they say is the right answer.
I think you misunderstood the question, the second number is the uncertainty on the first.
So the question is 7.8m/1.15s and then from the uncertainty in the values you are given decide how many figures you are justified in using in the answer.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
