Easy question, looking for quick help
  • Thread starter Thread starter IntegrateMe
The weight of an object on the moon is one-sixth of its weight on Earth, but this does not affect its kinetic energy. Kinetic energy is calculated using the formula KE = 1/2 mv², where mass remains constant regardless of location. Therefore, the kinetic energy of a body moving at speed V is the same on both the moon and Earth, leading to a ratio of 1:1. The initial confusion arose from conflating weight with mass in the calculations. Understanding that mass is invariant while weight varies due to gravitational acceleration clarifies the mistake.
IntegrateMe
The weight of an object on the moon is one-sixth of its weight on Earth. The ratio of the
kinetic energy of a body on Earth moving with speed V to that of the same body moving with
speed V on the moon is:
A. 6:1
B. 36:1
C. 1:1
D. 1:6
E. 1:36
I did the calculations using KE = 1/2 mv2 and got A, but the answer is C. Any explanations? Thanks.
Using KE = 1/2 mv^2 you would get the same answer on the moon as on Earth. The formula has MASS in it, not WEIGHT. The mass of an object is the same on the moon as it is on Earth. The weight, F = mg, is different because the gravitation acceleration g is less on the moon.
Wow, thanks for that! Such a silly mistake.
