Effective Current Impedance Calculation without Inductive Coupling
  • Thread starter Thread starter radicaled
    Current
The discussion focuses on calculating effective current impedance without considering inductive coupling. The impedance is calculated using the formula Z = √(R² + (Xl - Xc)²), resulting in a magnitude of 1414.21Ω. It is noted that while the impedance magnitude can be treated as a simple resistance for current calculations, it does not provide phase information related to the applied voltage. The importance of using complex impedance for accurate phase calculations is emphasized. Inductive coupling, which involves the interaction of inductors through a mutual magnetic field, is to be disregarded in this scenario.
radicaled
The exercise goes like this:
- Obtain the impedance
- Current effective without inductive coupling
Data:
v(t) = 100 sin(1000t + π/3)
R = 1kΩ
L1 = L2 = 1H
C= 1μC
Resolution:
Z = \sqrt{R^2 + (Xl - Xc)^2}
Z = \sqrt{1000^2 + (1000.2 - \frac{1}{1000 1x10^{-6}})^2}
Z = 1414,21Ω
Now, what is the inductive coupling
Without a circuit diagram the question is ambiguous. Can you provide a circuit diagram and the original problem statement?
Ok, I have attached the circuit.
As for the problem statement its the same. I may rephrase, because I have to translate it
- The effective current without inductive coupling
You've calculated a magnitude for the impedance, but the impedance itself will be a complex value (real and imaginary parts). You can find the magnitude of the current that flows by treating the impedance magnitude as though it were a simple resistance. Note that this will not provide current phase information (with respect to the applied voltage, which as you should note, has its own specified phase). For the phase information you will have to use the complex impedance and perform the calculation using complex arithmetic.
Inductive coupling is the interaction of inductors that share a mutual magnetic field; current in one inductor induces a current in the other, and vice-versa. Apparently you're asked to ignore such a coupling in this problem.
