Effects of a moving mirror on a ray of light
The discussion revolves around the effects of a moving mirror on the path of a ray of light, particularly focusing on scenarios where the mirror moves at subluminal speeds. Participants explore theoretical implications, potential experiments, and the relationship between the angle of incidence and reflection in different reference frames.
  • Some participants propose that if a mirror moves at subluminal speeds, the reflected dot on a wall will gradually move up over time.
  • Others argue that if the mirror is moving at subluminal speeds from the beginning, the reflected dot will remain fixed, although it may be higher than when the mirror is stationary.
  • A participant mentions that momentum is transferred to the light beam, resulting in a Doppler shift upon reflection.
  • Some suggest that the angle of reflection may change due to the motion of the mirror, particularly when considering different reference frames.
  • One participant introduces the concept of different frames of reference, indicating that the angle of light at the mirror differs depending on whether the mirror or the light source is considered to be in motion.
  • Another participant draws an analogy between moving mirrors and the techniques used by tennis players to control the direction of a ball.
  • A later reply discusses a paper that presents a relativistic treatment of light reflecting from a uniformly moving mirror, suggesting that the momentum change of each photon is perpendicular to the mirror's surface.
  • Some participants assert that if there were a significant effect from the mirror's motion, it would be observable in everyday reflections.
  • One participant posits that an ideal mirror, which exchanges momentum only along the y-axis, would not be affected by movement along the x-axis, likening it to a collision with a frictionless surface.
Participants express multiple competing views regarding the effects of a moving mirror on light reflection, with no consensus reached on the outcomes or implications of the scenarios discussed.
Some discussions involve assumptions about the ideal nature of the mirror and the conditions under which the effects are analyzed, including the treatment of momentum and reference frames.
yrjosmiel
Let's say I have an apparatus that's set up like this
Let's also say that the mirror is infinitely long.
If the mirror starts moving at subluminal speeds in the x axis, what would happen to the path of the ray of light? Would the dot made by the ray of light on the wall go up?
The reflected dot will go up over time, yes.
I believe you will also find that the angle of incidence and the angle of reflection will not match. If you bounce the light from a stationary mirror and from a moving mirror that is [momentarily] at the same position, the reflected light from the moving mirror will strike the screen farther up. But I do not have any calculations to back that up with.
That's if the mirror is accelerating to subluminal speeds, right?
If the mirror was moving at subluminal speeds from the very beginning, it will stay fixed, but at least still higher than when the mirror is stagnant, right?
Has anyone done an experiment on this? Would it be worth doing an experiment on? Of course, we don't have an infinitely long mirror at our disposal but I think a spinning mirror can emulate the scenario.
Not certain what's being asked, however, since momentum is transferred to the light beam, it will be doppler shifted upon reflection.
No. That's if the mirror is moving at all. Try it with your bathroom mirror. Move a flashlight toward it and watch the reflected spot.
I thought this meant that the reflected dot will gradually go up.
Yes, the reflected dot will gradually go up as the mirror goes up. What's the confusion?
Oh... on the _x_ axis. Never mind. No effect.
jbriggs444 said:
No effect.
Hmmm. I was expecting for the reflected dot to actually go up due to special relativity. Length contraction was what I had in mind.
Let's say that the angle of reflection is θ. In this case, let's also say θ = 45° (this is with respect to the line perpendicular to the surface of the mirror). When the mirror is moving at subluminal speeds, it may seem to have no effect at first. However, when I shift the reference from the the laser to the mirror, the laser is now the one in motion. I thought that since the laser is the one moving in the mirror's reference frame, the laser would appear to be contracted. When you shorten one of the legs of a right triangle, the angles change. In turn, the angle of reflection will change to something less then 45°.
We have two frames: one in which the mirror is moving while the wall and light source are at rest; and one in which the mirror is at rest while the wall and light source are moving. The angle that the light makes at the mirror is different in the two frames, but the point where the light beam hits the wall is the same.
The point is still the same because the distance between the light source and the wall changed too, right?
Tennis players and table tennis players have hit techniques named slice, cut or top spin with moving their rackets during hit and controlling hit ball's moving direction. Don't moving mirrors play similar role with rackets for light?
Let us name these as Frame 1 and Frame 2, where mirror is moving relative to laser and wall.
In addition to these let us name frames in original physical condition, where all are at relatively rest.
Frame 3 : one in which the mirror, the wall and light source are all at rest
Frame 4 : one in which the mirror, the wall and light source are all moving with the same speed
Hit points are same in Frame 1 and Frame 2
Hit points are same in Frame 3 and Frame 4
But we have no reason to think that hit point 1,2 and that of 3,4 are same.
A complete analysis is fairly straightforward, although the algebra's a mess at the end. You can easily write down the path followed by a pulse of light emitted by the laser in the laser's frame such that it strikes the mirror at x=y=t=0. You can transform that to the mirror frame and calculate the reflected path - since the mirror's at rest, the law of reflection is trivial. Then you can transform back. The result I came up with is that I agree with the consensus - no effect.
If there was an effect it would be seen in everyday observations involving reflections.
I don't recall mirrors moving at subluminal speeds being part of my "everyday observations".
Isn't this what the Earth does when it moves in its orbit.
Stellar aberration.
Put a telescope on the mirror surface and the laser angle from the horizontal will decrease as the laser location will have shifted in the direction of motion.
The reflected ray will have its angle shifted down also.
The point of contact with the wall should appear to have become lower. YES?
Google finds http://dx.doi.org/10.1119/1.4720389, "A general principle for light reflecting from a uniformly moving mirror: A relativistic treatment", Galli & Amir.
Abstract said:
We investigate the reflection of light from a mirror moving at relativistic speeds and introduce a general principle to determine the relationship between the incident and reflected angles. This principle states that the momentum change of each photon is perpendicular to the surface of the mirror. We carry out sample calculations for various geometries.
I'd suggest trying their treatment, if one can get past the paywall, also analyzing it in the mirror frame, where we know the angle of incidence should be equal to the angle of reflection. I haven't attempted either at this point, though.
This paper cites some other papers on the same topic, so it'd probably be a good idea to read those, too.
We have to put mass of mirror is infinite so that we can neglect repulsion of mirror even in case light becomes high energy gamma ray in moving mirror IFR.
If it's an ideal mirror, which exchanges momentum along the y-axis only, then there will be no effect from it's movement along x. It's analogus to collision with an ideal friction-less surface.
Indeed.
In fact, you can use the y-axis-only property of the reflection to follow my earlier procedure without doing any maths. The four momentum of the incoming light in the laser/wall frame is ##(p_t,p_x,p_y,0)##, which becomes ##(p_{t'},p_{x'},p_y,0)## in the mirror frame, since ##p_{y'}=p_y##. The reflection just flips the sign on the y' component, and the inverse transform takes the momentum back to ##(p_t,p_x,-p_y,0)##. So there's no effect.
A subluminal speed is any speed less than the speed of light. I'm guessing that you meant to refer to "relativistic speeds", in other words speeds close to the speed of light.
That's my analysis as well, based on analyzing the reflection from a stationary mirror in a moving frame. We can model the light be either its 4-frequency, or it's energy momentum 4-vector. The y-momentum of the light pulses won't be changed by the boost, the x-momen will be changed in identical ways for the downwards and upwards pulse. The result is that the angle of reflection should be equal to the angle of incidence in the moving frame as well as in the stationary frame.
At least according to my analysis, I've quoted the references google found but not read them due to a lack of access.
Finally, I understand what's being asked. No momentum is transferred to the beam in the rest frame of wall and laser. The boundary conditions on the surface of the mirror are unchanged by the translation speed IMO.
It would seem that the reflective properties of a real mirror are frequency or wavelength dependent. For example in the x-ray bands most household mirrors will become more transparent. If the mirror is normal to the beam and moving toward the laser fast enough, the beam in the mirror rest frame would blue shift to x-rays and the mirror start to become transparent. As the mirror normal is rotated [1] away from the beam direction the fresnel coefficients in the rest frame of the mirror are determined by the material properties in x-rays. Near grazing to the mirror surface the reflectivity will increase. This increase in near grazing incidence is how x-ray telescope optics are made. For the original post, the question is at what angle is the laser beam hitting the mirror in the mirrors rest frame?
[1] both beam and velocity vectors left unchanged as the mirror normal rotates.
I've done some solving and I'm not sure if I'm right, but here's what I got anyway:
let θo be the original angle of reflection (with respect to the perpendicular of the surface of the mirror)
θf be the final angle of reflection
Lo be the original distance (just in the x axis) from the light source to the point where the light ray hits the mirror
Lf be the final distance
If I recall my high school trigonometry,
Once the mirror starts moving, the distance L will appear to be shorter in the mirror's reference frame and will contract to Lf
How much a length is contracted is determined by:
Simple substitution leads me to:
What is "original" vs. "final"? Before vs. after reflection? Stationary vs. moving mirror?
Sorry: the "original" is when the mirror is not moving. The "final" is when the mirror is moving.
Okay, so what is your conclusion or remaining question (if any)?
So far, after taking into account the contraction of the distance of the light source and the wall, I concluded that there is indeed no difference in where the laser dot will land on the wall.
If I do have any remaining questions: should I do an experiment to confirm this conclusion or would that be a waste of time and resources?
How fast do you think you need to move the mirror to see an effect if you are wrong?
  • · Replies 93 ·
  • · Replies 23 ·
  • · Replies 34 ·
  • · Replies 51 ·
  • · Replies 45 ·
