Efficiency of engine taking diatomic ideal gas through cycles
The discussion focuses on calculating the thermal efficiency of an engine operating with diatomic ideal gas through a specified cycle. The efficiency formula is given as e = W/Qh, with the final answer noted as 10.5%. Participants are encouraged to find temperatures at all four cycle points, which are derived as T0, 2T0, 4T0, and 2T0, respectively. The heat absorbed during the isochoric and isobaric processes is calculated using the equations Q = n Cv ΔT and Q = n Cp ΔT. The overall conclusion emphasizes the need to understand the relationships between pressure, volume, and temperature to solve the problem effectively.
jensgt
What is the thermal efficiency of an engine that operates by taking n moles of diatomic ideal gas through the cycle 1 -------> 2 -------> 3 -------> 4 ------> 1 shown in the figure ?
http://s3.amazonaws.com/answer-board-image/2d50cb1e-1bc6-4325-acf6-fe1df4f0a7b5.jpeg
e = W/Qh
I know the answer is 10.5
I am trying to prep for a test today and this is the last thing from my homework that I don't understand...can someone explain to me how the answer is generated? I am sort of lost on it and I figure it has to be easier than it seems.
There are two isochoric and two isobaric processes in the cycle. Find temperatures at all four points and calculate the heat absorbed from the source and the net work done.
The efficiency is always less than one thus it must be 10.5%.
How to find temp with no p or v numbers?
It is P0V0/nR at 1.
I'm still confused...po is not a numerical value.
say P0V0/nR = T0 then what are temperatures at 2, 3 and 4 ?
these are 2T0, 4T0 and 2T0 respectively.
Now find the heat absorbed in isochoric and isobaric processes using Q = n Cv ΔT and Q = n Cp ΔT
