How Much Elastic Energy Is Stored in the Achilles Tendon?
  • Thread starter Thread starter dvolpe
    Elastic Energy
The discussion centers on calculating the elastic energy stored in the Achilles tendon using the maximum tension of 4.5 kN and a spring constant of 360 kN/m. The correct formula derived from Hooke's Law is Energy = 1/2 * k * x squared, where x is determined to be 0.0125 m. Initial calculations yielded an incorrect energy value of -0.0281 kJ, prompting questions about unit conversions. It was clarified that the spring constant should be converted to N/m, and the final energy value should be positive, indicating the correct approach to the problem.
dvolpe
If the maximum tension in the Achilles tendon when the foot is sent down is 4.5 kN and the tendon's spring constant is 360 kN/M, calculate how much elastic energy is stored in it.
F = kx
Hookes Law: Energy = 1/2*k*x squared
Got x from F = kx x = 0.0125 m this is correct per submission.
Then substituted all values into Hookes law and got energy = .0281 J This was wrong according to submission.
If the elastic energy is a measure of the potential energy, how do I find that?
Your formula for energy should work. Did you properly convert the units?
Yes I converted th distance x of 1.25 cm to .0125 m. The constant is 360 kN/m . Wait..do I need to convert the constant to N/m?
Which then makes the answer -.0281 KJ or -28.1 joules, correct?
Yes. However your answer would be positive and not negative.
