How Do You Calculate the Electric Charge of a Sphere?
To calculate the electric charge of a sphere, the electric field strength at a distance from its center is essential. Given an electric field of 30,000 N/C at 0.1 m from the sphere's center, the charge can be determined using the formula E = kQ/r², where k is Coulomb's constant. The radius of the sphere is 0.05 m, but the charge is calculated based on the distance from the center. The final calculated charge of the sphere is 3.3E-8 C. This demonstrates the application of electric field equations in determining charge.
Ryo124
You have an electrically charged sphere.
The strength of an electric field 0.1 m away from the center of the sphere is 30,000 N/C.
The radius of the sphere is 0.05 m.
What is the electric charge (Q) of the sphere?
E = F/q - E = -V/d
I don't know how to attempt this problem, I'm not even sure if these equations are relevant. Someone please help.
Nevermind, I got it. 3.3E-8 C
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
