Electric Current of an Orbiting Electron
The discussion focuses on deriving the constant k in the equation I = e² / √(kε₀r³m) for an electron orbiting a proton in the Bohr model. The user starts by equating Coulomb's force law to centripetal force, leading to the equation ω² = ke²/mr³. They then attempt to express angular frequency in terms of the period, resulting in 2π/T = ke²/mr³. A typographical error is noted in the left side of the equation, and the user is advised to utilize the relationship I = q/t to further manipulate the equations. The conversation emphasizes the need for clarity in deriving the desired form of the equation.
FelaKuti
The question is based on the Bohr model with an electron with charge e and mass m orbiting a proton about a circular radius r.
I have to find k in the equation I = e2 / sqrt kε0r3m
where k is a some combination of constants.
Coulumb's force law: F = kq1q2/r2
Centripetal force: mω2r
Current: I = q/t
k = 1/4πε0
I equated columb's force law to the centripetal force to give mω2r = ke2/r2
Then rearranged to get ω2 = ke2/mr3
Then I changed ω for 2π/T and square rooted both sides to give 2π/T = ke2/mr3
From here I'm just not sure how to get it into the form of the equation asked for.
FelaKuti said:
ω2 = ke2/mr3
2π/T = ke2/mr3
The left side of the second equation above has an error (maybe just typographical).
Try to make use of I = q/t.
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 16 ·
