Electric engine for car vs Electric Engine for Drone
Electric engines for cars and drones operate on similar principles but differ significantly in design and components. Cars, like the Tesla Model S, typically use three-phase AC motors, while drones generally utilize brushless DC motors. Both types of engines contain a stator and rotor, but they are optimized for different performance metrics; drone engines prioritize power-to-weight ratios, while car engines focus on efficiency and regenerative braking. The mention of an ignition coil is incorrect in the context of electric engines, as it is associated with internal combustion engines. For further information, searching for "brushless DC motor diagram" can provide valuable insights into drone motor schematics.
Futurestar33
Hello,
I am trying to find out if there are any differences between how the Electric engine for car works vs how an Electric Engine for Drone works.
I am sure the both consist of an Ignition coil, stator and rotor. However I have not been able to find the any schematics for a drones electric engine. If anyone has any recommendations on where to look or can provide the information themselves. Please let me know.
Thank you
It probably depends on the car, but the Tesla S uses 3 phase AC motors and drones use DC motors. Schematics of actual products may not be easy to come by though -- what exactly are you wanting to know/do?
I am wanting to know whether the Electric engine of the drone uses the same aspects as the car, such as ignition coil, stator and rotor and other key magnetic components.
Both contain a stator and rotor, but they are different from each other...and I don't know what an "ignition coil" is, but I don't think it is a part of either. Have you looked at articles describing the parts of these motors?
The electric engines work on the same principles in both cases. How big is the drone ?
A drone engine will be more expensive and be designed for best power to weight ratio.
The car engine will have a lower power to weight ratio and be designed for high efficiency and for efficient regenerative breaking.
An ignition coil is used with a distributor and spark plugs in an internal combustion, gasoline engine.
Likes russ_watters and billy_joule
Well that is upsetting about the ignition coil =/, idk where i read that they were used in electric engines. I am going to continue to do more research. Thank you guys.
Maybe you were reading about Hybrid cars at the time.
Likes donpacino
If your talking about modern quad copter drone motors, and the like, just google" Brushless D/C motor diagram"
Likes donpacino and berkeman
