Electric field at a distance greater than the radius of sphere
To determine the electric field E(r) at a distance greater than the radius of a uniformly charged solid ball, the correct formula involves using the total charge Q and the area of a sphere. The charge Q is calculated as Q = ρ * (4/3)πr_b^3, where ρ is the charge density and r_b is the radius of the ball. The electric field formula should be E(r) = (Q/ε_0) * (1/(4πr^2)), reflecting the area of a sphere, which is 4πr^2, not (4/3)πr^3. The initial misunderstanding about the area and charge calculation was clarified during the discussion. The correct approach leads to the proper expression for E(r) at distances greater than r_b.
rocapp
A solid ball of radius rb has a uniform charge density ρ.
What is the magnitude of the electric field E(r) at a distance r>r_b from the center of the ball?
E(r) = (Q/ε)*1/Area
If Q=ρrb
and Area = (4/3)πr3,
then E(r) = \frac{ρr<sub>b</sub>}{ε*(4/3)*πr<sup>3</sup>}
However,
the correct answer is in the image attached.
E(r)=
=%5Cfrac%7B%7B%5Crho%7D+%7Br_%7Bb%7D%7D%5E%7B3%7D%7D%7B3+%7B%5Cepsilon%7D_%7B0%7D+r%5E%7B2%7D%7D.gif
Area is not (4/3) pi r^3
Also, Idon't think q = prb
Oh. I get it now. Thanks!
