yjk91
- 73
A -5-nC point charge is located at the center of a conducting spherical shell. The shell has an inner radius of 2 m, an outer radius of 4 m, and a charge of +7 nC. (Let the radially outward direction be positive.)
(a) What is the electric field at r = 1 m? (Indicate the direction with the sign of your answer.)
(b) What is the electric field at r = 3 m? (Indicate the direction with the sign of your answer.)
(c) What is the electric field at r = 5 m? (Indicate the direction with the sign of your answer.)
(d) What is the surface charge distribution, σ, on the outside surface of the shell? (Indicate the direction with the sign of your answer.)
a) you get this by doing -5 * 10^-9 * 9 * 10^9 / (1) ^2 = -45 N/C
(b) 0 N/C
i' not sure of this i thin it's because it's on the middle. Middle meaning middle of 2 M and 4 M which is 3M
i would like a clear answer
Units are required for this answer. 0.719 N/C
this i have no idea.. i think there is a formula but not sure how the charge of 7nC affects the field
i think you use E = σ/epsilon0
