Is the Electric Field Zero Inside Any Shape of an Empty Cavity in a Conductor?
The electric field inside an empty cavity in a conductor is zero, regardless of the cavity's shape, due to the behavior of charges in conductors. When a conductor is placed in an external electric field, its free electrons redistribute, creating an opposing field that cancels the internal field. Since the cavity is empty and contains no charge, there is no net charge density influencing the electric field inside it. The only charges present are on the surface of the conductor, which do not affect the cavity's interior. Therefore, the statement holds true for any shape of cavity in a conductor.
hisashiburi
The electric field inside an empty cavity in a conductor is zero. Is this statement true no matter what the shape of the cavity? Why or why not?
Electric field equation. E = kQ / R^2
I can't seem to figure out if this is true no matter what the shape.
no, consider a charge in a cavity in a conductor.
it's only in the meat of the conductor, because when you would put a conductor in a field, the electrons would move and create a field with the protons on their own. The two fields tend to cancel. But in a hole, you don't have this problem. (The edges of the conductor will be charged however, in that case.)
That's correct, but it's stated that the cavity is empty, so it doesn't contain a charge. There's no net charge density in the conductor and the cavity is empty, so the only place a charge could be is on the surface of the cavity. Now consider a gaussian surface around the cavity but inside the conductor.
oh I'm sorry, ah well... I guess Dick gave you quite a hint there.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
