Electric Field/ infinite charged sheet
The discussion centers on understanding the electric field produced by three charged sheets with different charge densities. The electric field due to an infinite sheet is given by the formula E = σ/2ε, where σ is the charge density. The user is confused about why the electric field vectors from sheet 2, which has a negative charge density, are twice the magnitude of those from sheets 1 and 3, which have positive charge densities. Clarification is provided that the center sheet's surface charge density is -2σ0, explaining the discrepancy in magnitudes. The conversation emphasizes the consistent application of Gauss' Law and the properties of electric fields from charged sheets.
Andy13
There are three charged sheets with various charge densities. The following link shows a diagram, and solutions (not mine; these are some professor's solutions but I don't understand them yet):
http://www.phy.syr.edu/courses/PHY212.08spring/HW/WHW-3.pdf
Draw vectors at each of the points A-D to show the direction and relative magnitude at the point due to a) sheet 1 b) sheet 2 c) sheet 3.
E field due to infinite sheet = σ/2ε
(where ε = permittivity constant and σ = charge density)
Flux = ∫ EdA = E*A = |E||A|cos(θ)
Gauss' Law: Flux = q(enclosed)/εo
I know which direction the vectors go, but I don't know what their magnitudes are. Surfing the internet gave me this (scroll to last page):
I know that the magnitudes of each vector of the electric field from each individual sheet from points A-D should be equal, because the electric field from a charged sheet doesn't depend on radius (for example, sheet 1's field could give vectors of magnitude |a| at every point).
However, I don't understand why sheet 2 (σ = -1), according to the above solutions, has vectors of twice the magnitude of sheets 1 and 3 (σ= +1). What am I missing?
I agree with you.
His solution is consistent with the center sheet having a surface charge density of -2σ0 .
(I have taught this subject for more than 20 years.)
SammyS said:
I agree with you.
Thanks SammyS-- I'm glad I wasn't misunderstanding something.
