Electric field inside a non uniform spherical distribution.
The discussion revolves around calculating the electric field inside a non-uniform spherical charge distribution defined by the density ρ(r) = Qr/πR^4. Participants explore how to determine the enclosed charge q using the charge density and the volume element in spherical coordinates, ultimately identifying that dV = 4πr^2dr is appropriate for this problem. One user successfully calculates the electric field and confirms that option C is correct. The conversation also touches on the importance of providing clear guidance in homework help threads to ensure students receive adequate assistance. Overall, the thread emphasizes the collaborative nature of problem-solving in physics.
takando12
Let ρ(r)= Qr/πR4 be the charge density distribution for a solid sphere of radius R and total charge Q.For a point 'P' inside the sphere at distance r1 from the centre of the sphere, the magnitude of electric field is ?
A) 0
B) Q/4πε°(r1)2
C) Q(r1)2/4πε°R4
D) Q(r1)2/3πε°R4
Constructing a spherical gaussien surface on which point P lies,
Φ= EΔs=q/ε°
E4π(r1)2= q/ε°
where q is the charge enclosed by the gaussien surface.
I'm having trouble as I don't know how to find q. I know dq= ρdv and so q=∫ ρdV , but if I do substitute ρ in that integral , I don't know what to do with the dV.
Please give me a hint as to how to proceed.
Have you been taught what is the expression for the volume element ##dV## in spherical coordinates?
No, we were not taught anything like that. Is that the only way, whatever it is?
You don't need the general expression for the volume element ##\ dV \ ## in spherical coordinates.
The distribution has spherical symmetry, so you can find ##\ dV \ ## as follows.
A sphere of radius, ##\ r\,,\ ## has a surface area of ##\ 4\pi r^2\ ## so a spherical shell of radius, ##\ r\,,\ ## and thickness, ##\ dr\,,\ ## has a volume of ##\ dV=4\pi r^2dr\ .##
Use that for ##\ dV \ .##
Likes takando12, Delta2 and conscience
Ok, well SammyS suggestion saves you from extra work and keeps you inside what you already know without the need for the general expression for dV.
However , my egoism and jealousy (oO?!?) (the most common traits of all human beings regardless of race, culture, religion or whatever) makes me to say that my suggestion is not wrong, it is correct also, it just requires some extra work...
Your suggestion is correct .But SammyS 's suggestion should invariably be the first line of approach (easier and simpler) .
I am Ok with jealousy part :smile: , but the egoism part has forced me to write this reply :wink: .
Honestly , I was really surprised when I read your initial suggestion to the OP of using "spherical coordinates" . I was even more surprised to read this
Delta² said:
At the moment can't think of other way on how to integrate to get the enclosed charge
I have read few of your responses on PF and I think you are pretty good . Your knowledge is far superior to mine . But I have a couple of suggestions .
1) When anybody decides to post in a Homework Help thread , he/she should be confident of providing complete assistance . Because as soon as the first response is made , that takes the thread out of the radar of almost every experienced HH ( by taking it out the unanswered thread list) . The probability of any other HH chipping in becomes very less . So if the OP does not get proper assistance at his required level , the poor guy is left in a lurch . I have seen this here at PF .
2) Even if somebody knows advanced stuff , the first level of attacking the problem should always be something simpler ( if possible) .
I hope the common traits of a human are not interfering in acknowledging the above points :smile: .
Likes takando12 and Delta2
yes, point 1) is pretty strong but (egoism interfering) it doesn't mean HHs know better than ME, they just know how to help better :D
Likes takando12 and conscience
Thanks for acknowledging this point . Not many do .
Absolutely :smile: .
Please continue helping students and sharing your knowledge .
Yes, that is within my school level jurisdiction.
It works and I got option c) which is right.
Thank you,
@SammyS and @Delta² for the legal and illegal solutions respectively. Alas, we don't learn lots of beautiful things in school.
and @conscience for highlighting the daily horrors of the OP. We sometimes get petrified when we hear completely fresh concepts that we have never encountered before.
:smile: Long live the egotist.
Likes Delta2
