Electric Field of a Hollow Cylidrical Conductor
The discussion focuses on determining the electric field of a hollow cylindrical conductor using Gauss' law. It emphasizes that the electric field's magnitude depends solely on the distance from the z-axis, with distinct calculations needed for regions inside (r < R) and outside (r ≥ R) the conductor. Participants suggest using a cylindrical Gaussian surface with a surface area of 2πrl to leverage symmetry effectively. The conversation concludes with a user expressing satisfaction after successfully applying the guidance provided. Overall, the thread highlights the application of Gauss' law in electrostatics for cylindrical geometries.
Zook104
Consider a hollow cylindrical conductor in vacuum with its axis aligned with
the z-axis, and with a positive surface charge density σ. The direction of the
electric field is radial and its magnitude E is only a function of the distance r
from the z-axis, E = E(r).
Use Gauss' law to obtain the magnitude of the electric field at r < R and
at r ≥ R, where R is the radius of the conductor.
I don't know whether I have got my brain stuck in a rut but I can't for the life of me solve this. Any and all help will be greatly appreciated :D
hey, welcome to physicsforums!
Try using Gauss' law, as it says. What kind of Gaussian surface should you use to take advantage of the symmetry?
A cylindrical surface? With surface area of 2\pirl ?
Or should I just use a circular one because the conductor is infinite either side?
Use the cylinder with surface area of 2*PI*r*l
Do the calculation using the information they have given you, and it should all come out nicely. (Even though the conductor is infinite, it doesn't go bad).
Go with that one.
Excellent I believe I have got the correct answer :D Thank you so much for your help
