Electric Field on two non-parallel plates
The discussion centers on the behavior of electric fields between two non-parallel plates arranged in a V shape. It highlights the confusion regarding why the electric field, which is straight between parallel plates, becomes curved when the plates are angled. The key point is that electric field lines must be perpendicular to the surface of the plates at the point of intersection, leading to the curvature of the field. The participants explore the relationship between electric field lines and potential surfaces, noting that analytical solutions for this configuration are complex. Ultimately, the reasoning concludes that the electric field's curvature is a result of the geometry of the plate arrangement.
Seydlitz
Why the electric field is in fact curved in that configuration? I'm just a little bit confused because normally if the plates were arranged parallel the electric field were perfectly straight, the electric field of infinite plane is also straight. Why then suddenly when the plates are angled the electric field became curved?
On what principle could I infer this from without calculating anything?
Thank You
Edit: By non-parallel in my case, the plates are arranged forming a V.
The lines that represent equal field strength have to be perpendicular to the plates at the point of intersection? Is that true? If so, why is it so? Perhaps that is the key to answering your question.
DC
DC
I'm sorry but I don't think I understand your statement. Could you rephrase it in someway, perhaps in reference to familiar examples like electric dipole or point charges?
Edit: What I know already is the electric field line must always be perpendicular to the surface of electric potential, and hence conductor but I can't get my mind to relate this concept to the non-parallel plates. Moreover, it seems the electric field cannot be solved analytically also.
Ahhh!
I think I know what you mean. Because of that reasoning the electric field must emanate perpendicularly to the plate. Hence, it would be impossible for it to have a straight field like if they were to be arranged in parallel. In the end the electric field will be curved. Does my crude prove by contradiction reasoning correct? :D
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
It may be shown from the equations of electromagnetism, by James Clerk Maxwell in the 1860’s, that the speed of light in the vacuum of free space is related to electric permittivity (ϵ) and magnetic permeability (μ) by the equation: c=1/√( μ ϵ ) . This value is a constant for the vacuum of free space and is independent of the motion of the observer. It was this fact, in part, that led Albert Einstein to Special Relativity.
