Electric field produced by 2 point charges
The discussion focuses on calculating the total electric field at point P due to two point charges, both with a charge of -2.78x10^-10 C. The electric field produced by charge A at point P is 40.0 N/C directed south. The electric field produced by charge B, located 0.250 m south of A, is calculated to be approximately 10 N/C also directed south. Since electric fields from both charges add as vectors, the total electric field at point P is determined to be 50 N/C directed south. The solution confirms the correct approach to adding the electric fields.
rowkem
A small object A, with a charge of -2.78x10^-10 C, creates an electric field. At a point P located 0.250 m directly north of A, the field has a value of 40.0 N/C directed to the south. If a second object B with the same charge as A is placed at 0.250 m south of A (so that objects A and B and point P follow a straight line), what is the magnitude of the total electric field produced by the two objects at P?
So basically:
B<----0.250m----A<----0.250m---->P
Not N-S but same idea.
E=k(q/r^2)
Well, I don't know if electric fields add like vectors. I worked out the electric field produced by B, at point P, is about 10 N/C south. Given its only asking for magnitude, would it be correct to add the two fields together to get the net field at point P to be 50 N/C?
Took a stab at it. I was correct. Thanks regardless.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
