What is the Charge on a Bead Accelerating in a Uniform Electric Field?
A small charged bead with a mass of 1.0 g is released in a uniform electric field of 200,000 N/C, resulting in an upward acceleration of 20 m/s². The discussion revolves around determining the charge on the bead using force equations. Participants clarify that the relevant equations include F = qE, F = mg, and F = ma, emphasizing the application of Newton's second law. By setting the sum of forces, Eq - mg = ma, the relationship between the forces becomes clearer. The problem highlights the importance of correctly applying dynamics principles to find the charge.
Sarah88
A small charged bead has a mass of 1.0 g. It is held in a uniform electric field E= 200,000 N/C up. When the bead is released, it accelerates upward with an acceleration of 20 m/s^2. What is the charge on the bead?
F= qE
F= mg
(possibly F= ma)
I tried this problem multiple different ways including:
mg-Eq= 0
as well as Eq= ma
However, I wasn't sure how to relate the three force equations (mg, ma, Eq) together for this problem (because all seem relevant in this problem). Thank you!
Welcome to PF!
Hi Sarah! Welcome to PF! :smile:
mg-Eq= 0
as well as Eq= ma
Well, you're nearly there :wink:
as in almost all dynamics problems, just apply good ol' Newton's second law …
sum of forces = mass times acceleration …
what do you get? :smile:
Hi,
Thanks for the welcome to the forum :)
Well, the sum of forces equal to ma: Eq- mg (oppose each-other) = ma, it makes a lot more sense when you take into account Newton's second law. Thank you for your help! :)
