How Does Gauss' Law Apply to Electric Flux Through a Cube's Surface?
  • Thread starter Thread starter Go Boom Now
    Electric Law
A 10 nC point charge is located at the center of a 2 m cube, and the discussion revolves around calculating the electric flux through the cube's top surface. The relevant equations for electric flux and electric field due to a point charge are provided. It is clarified that since the charge is centered, the cube is closed and uniform, leading to the conclusion that the total flux is evenly distributed across all six faces. The total electric flux is calculated using Gauss' Law, resulting in approximately 1129.94 N m²/C for the entire cube, with 188.32 N m²/C passing through the top surface. The discussion emphasizes the application of Gauss' Law in determining electric flux in symmetrical situations.
Go Boom Now
A 10 nC point charge is at the center of a 2 m x 2 m x 2 m cube. What is the electric flux through the top surface of the cube?
Electric Flux = E x A x cosθ
Electric Flux = ∫E x dA = Q(inside)/ε
E (point charge) = kq/r^2 where k = 1/(4pi ε)
Aside from finding the area, volume, and anything else that might be considered obvious, I've no idea where to head from here. I'm not sure if the cube is completely closed or if the top surface isn't uniform. I'm hoping someone can help walk me through this problem.
It's an imaginary cube. So it's closed and doesn't have any properties that could be nonuniform. You can compute the total flux through the cube, right?? Any reason to believe that more passes through one face than any other?
I'm... not sure? The point charge is in the center of the cube itself, so... no?
Ok, so 1/6 of the total flux must pass through each face. Total flux is easy to compute.
I think I got it.
Total Flux of Cube = Q (charge) / ε = (10x10^-9) / (8.85x10^-12)
1129.94 / 6 = 188.32 N m^2 / C.
This is the answer I was given. Thanks for the help!
