Electric & magnetic dipole moment
Grufey
Hello, I have doubts with this problem, I'm not sure, if my solutión is right, so, here we go
Let's two equal charges with the same charge but opposite signs, positive and negative, in a circle, such a distance between them is constant and equal to diametre of the circle. Both charges, turn around the center of the circle with angular speed w. Calculate, the electric dipole moment, and the magnetic dipole moment.
the electric dipole moment, is define as, \vec{p}=q\vec{d}, with \vec{d} the vector that go from the positive charge to negative charge.
The system turn around the center, so we have to applicate a rotational matrix to \vec{d}, and so, we have calculated the electric dipole moment
The magnetic dipole moment, must be zero, because the charges have opposite signs, and the problem is equivalent to two spirals with circulating intensites in opposite directions.
I think that my solution is too simple, for this reason I mistrust it
Thank's
Electric dipole moment of a system:
<br /> \vec{d} = \sum_{a}{q_{a} \, \vec{r}_{a}}<br />
where q_{a} is the charge of the ath particle and \vec{r}_{a} is its position vector. The summation goes over all the particles of the system.
Magnetic dipole moment:
<br /> \vec{m} = \frac{1}{2} \, \sum_{a}{q_{a} \, (\vec{r}_{a} \times \vec{v}_{a})}<br />
where \vec{v}_{a} = d\vec{r}_{a}/dt is the velocity of the ath particle and \times stands for the vector product between the two vectors.
Thank's, for your answer.
I am glad to have it well. If we calcule the moment, with your definition, we recover, my result.
So, Thank you again
So, Thank you again
actually, no. The electric dipole moment of two opposite charges is always directed from the negative towards the positive one.
I agree, sorry. I was wrong.
Thank's
You are right about the magnetic moment though. It is zero. The simplest way to look at it is, to ask yourself what the current carried by two opposite charges moving along a circle with the same frequency is. It is zero, and no current implies no magnetic moment.
I think that the problem is similar to two magnetics domains with opposite spin, the resultant moment is zero, or two electrons, spirals...
No. If two electrons were orbiting around a common center, then the magnetic moment would not be zero, but the electric dipole moment would have been. This is more like the positronium atom, where an electron and a positron orbit around a common center of mass. Also, we have to neglect the spin of the charges, since there is no classical analogue to spin.
Then, two electrons were orbiting around a common center, have magnetic moment, iff, turn around in the same direction.?
I understood the positronium's example, thank's
oh, did you mean two electron orbiting in opposite directions? Yes, that is also a viable option.
