Electric potential difference between a battery's + terminal and the ground
83 replies · 24K views
cianfa72 said:
If there exist an excess of electrons on it (even if, as said before, the overall battery net charge is nevertheless zero) why the meter connected between it and the ground (Earth) will not flow any current through it measuring a non-zero voltage ?
Where does this excess charge come from? If there was an excess charge unless this excess charge is replenished simultaneously as flows to ground through the meter the flow would progress at the speed of light and would have to be sustained which would require what source of electrons? If electrons leave an equal quantity of positive charges would be left to prevent further electrons from leaving.
cianfa72 said:
The meter (voltmeter) has an high impedance nevertheless it allows current to flow. Thus, connecting it for instance between battery negative pole and the ground, I believe the excess electrons on the negative electrode will flow though the voltmeter towards the ground (we assume Earth basically is able to absorb or "pump" electrons without changing its potential). It that is true why it will not measure any voltage ?
No, this is still incorrect.
As has been pointed out several times in this thread, nothing will flow as there is no complete circuit back to the + terminal of the battery
Why you take in account the "mean" potential of the battery and not the potential of the negative terminal that will be grounded through the voltmeter in the experiment we are considering ?
I tried it today. I connected a 1.5 V battery with a small bulb and measured with a multimeter. The voltage difference between the two ends of the dry battery was 1.5 V. When the bulb burned, I noticed it was slightly less, about 1.4 V. I tried to find Earth potential - of course I didn't use the ground contact of the electrical socket - but the bathroom faucet, outside the terrace with the iron barrier, the iron column of the clothes dryer. Whether the electric bulb was burning or not, the multimeter did not show any electrical voltage to the ground. Absolute 0.
I've studied Sir Lawrence Bragg's excellent book, Electricity, which I've read before. In my opinion, the multimeter does not show a potential difference compared to the ground - you look at any pole, and whether there is current or not - because it is not. However, not only is there no difference in potential compared to the ground, but it is not between the battery plus and the minus poles. As L. Bragg explains, the electric current flows from the copper electrode to the zinc electrode outside the battery, while in the liquid the positive ions flow from the zinc to the copper electrode. Moreover, Bragg also asks the question: which electrode has greater potential?
In my opinion, this is a chemical process. Copper binds electrons better, so if the two electrodes are connected by a wire, the electrons start to flow into the copper. The zink electrode begins to decompose, and since the electron transfer causes the copper electrode to be negatively charged, zinc and copper ions with a positive charge in the liquid increase the copper electrode. Zinc is slowly running out, and the battery is exhausted. Thus, as a result of the chemical process, the copper electrode absorbs electrons from the zinc, the device shows an electric current, while there is, in fact, no potential difference between the two electrodes. (The migration of positive ions evidences this.)
I Can choose any reference point I like. The mean potential is the least arbitrary.
The problem here is that no one has actually produced a definitive diagram about this thought experiment. You say that nothing will flow but that would depend upon the self capacitance of the battery and the capacitance to Earth and also the absolute mean potential of the battery. But, seriously, we could all be discussing a different scenario.
Wise words...:oops:
242150
This is the basic schema we are discussing about using for instance a simple Daniell cell. Up to now we have defined no electrical model for it...can you propose one ?
ohhh and I forgot to mention earlier...
A voltmeter doesn't go in series with a circuit 😉
cianfa72 said:
Wise words...:oops:
Ok, that diagram just confirms previous comments by others and myself, there will be no current flow to GND
cianfa72 said:
Wise words...:oops:
Now change it to this configuration and it's a whole different story
Dave
ok, but...consider an initially isolated battery (e.g. Daniell cell): the zinc electrode has got an accumulated amount of (excess) electrons whereas the copper one an excess of positive charges (it turns out that when a sufficient amount of negative (positive) charges have been accumulated on the electrodes the chemical process will stop). There exist, thus, a voltage difference between them and (I suppose) between each of them and the ground (Earth).
Next, suppose at a given point in time you connect the zinc electrode (-) to the ground (Earth) through a voltmeter: could you explain which is the reason why no electrons will flow from the zinc electrode towards the Earth ?
I think there is a problem of labeling the electrodes with a + or - sign for it might imply to some that the electrode are a source or a bank of charges. It might be better to refer to them as the anode or cathode instead. Just a thought.
The excess of charge before the electrode are connected is due to the inter electrode capacitance which is of the order of picofarads. This might accumulate about 107 electrons. The potential difference of the cell is not due to the excess charges on the electrode for if it were then the physical size and placement of the electrodes in the cell would change the voltage across the cell which does not happen. If you ground the cathode no electrons will flow off it to ground because they are being held in place by the induced positive charges on the anode. Grounding the cathode does not change the potential difference between the electrodes.
ok, good point
Not sure to understand your point: for sure the electromotive force (emf) of a cell is determined by characteristics of chemical processes involved and, from the very definition of emf, it equals the potential voltage difference established across electrodes when the cell is "open" (no external conductive path between electrodes)
Could you please elaborate a bit this point ? Thanks
Although the amount of charge at the terminals is small, it seems that you could have a wire connected to an isolated plate or sphere that retains charge, and alternately connect the wire between the two terminals of an isolated battery (connecting only to one terminal at a time), to very slowly discharge a battery. I don't know if this could be considered as some type of intermittent circuit.
When you place a capacitor across the terminals it will charge to the potential of the battery. Only enough charge will be created by the chemical process to charge the battery to its emf according to this relationship'
Q = CVemf
If I connect a 1 uF cap and it charges to Q if I change the cap to 10uF the charge now will be 10Q because the voltage is the same.
The two electrodes form a capacitor so if the electrode size, relative distance from one another is changed the capacitance C will change resulting in different amount of charge.
Not much more. Giving an alternative path for the electrons like connecting the cathode to ground does nothing because the positive charges on the other electrode are attracting the electrons more than the ground so they stay put.
it's irrelevant ... for every - charge on the - electrode, there is a positive charge on the + terminal ... there is a balance
and an electric field that exists in the cell/battery between the 2 terminals
Adding a ground to either terminal IS NOT going to make any difference.
see my previous comment
davenn said:
it's irrelevant ... for every - charge on the - electrode, there is a positive charge on the + terminal ... there is a balance and an electric field that exists in the cell/battery between the 2 terminals
ok thanks, I believe got it.
Thus, just to check my understanding, the following two cases are actually different.
242187
In the first case (A) at the given moment conductor 2 (basically a plate of a capacitor) is grounded positive charges discharge towards Earth (or in equivalent way electrons from the Earth neutralize them) whereas in the second case (B) electrons on plate 2 do not discharge because of the "attraction/electrostatic induction" due to positive charges existing on plate 1. In any case electric potential of plate 2 reaches the same as Earth.
Does it make sense ?
@cianfa72
Your last paragraph could benefit from a switch to be included in the circuit, to make clear what is happening. IAnd, if you want to be really rigorous about your description, you could probably include a first diagram in the series, when t = 0 and the switch is open.
You are not going to get case A for the very reasons I stated in my previous post
you are not going to get + and - charges on the same terminal like that ...
the charge there is going to be equal and opposite to what ever is on the other terminal ... period
There is nothing wrong with drawing + and - charges on one plate. The resulting NET charge is what will count in the end. (It could perhaps have been better to draw two columns of + charges on the + plate to make this clear.
  • Skeptical
ok, as advised I re-drew the pictures as follows:
242193
Case A is just to help reasoning and does not represent the original scenario.
We can conclude that, upon turning on the switch, instantaneously the voltage difference between the plate and Ground will drop to 0 (as in the case there was a voltmeter inserted in series with the switch: upon switching it on instantaneously the initial difference voltage would drop to 0 too)
  • Skeptical
cianfa72 said:
instantaneously
You should avoid that word here. If you are trying to really get to the bottom of this then you need to assume that there are time constants involved; everything involves some delay. You have a tiny C (perhaps a few pF) discharging a tiny charge through a very high meter resistance (say 100MΩ) which means a time constant (RC) of less than 1ms but certainly not 0s. The charge flow would be probably enough to pick up as a small click on a radio receiver, places near it.
You're really talking about the first case (A) I guess. As highlighted several times in this thread, in the second case (B) there will be no current flow (no discharging) at all, nevertheless the voltage difference between plate 2 and Ground will drop to 0 (even with a voltmeter inserted in line) upon turning on the switch (perhaps in some pico-nano seconds)
But the second case is indeterminate - unless there is specific PD quoted, it could be anything. That's been my point all along. It's an equation with two unknown values. The actual PD of that arrangement, floating in space could be anything and you don't know its history.
ok but, whatsoever the potential difference of that arrangement is, why a voltmeter connected between the plate and the ground (case B) should not measure anything (not even a small variation/reading provided an enough slow discharge with an adequate time constant ) ?
cianfa72 said:
ok but, whatsoever the potential difference of that arrangement is, why a voltmeter connected between the plate and the ground should not be able to measure anything ?
A good enough voltmeter could measure the PD between any two points, anywhere. But why is that of interest in a very practical context like this one? Why would a PSU manufacturer be wasting time producing a device with 'infinite' insulation and with total EMI shielding?
This thread is about real EE unless, as I pointed out way back, you actually specify all the details of the circuit; in which case there could be an answer available. But you keep shifting the goal posts about what you want to know so there is no full answer available yet.
Try to 'follow the rules' of basic circuit theory and go along with how a Voltage Source behaves. Then, once you are familiar with them and can answer basic questions about simple ideal circuits, try introducing extra Resistances into the (non-ideal) circuit - 'near zero" series R and 'very high' parallel R and see what you get.
I would like emphasize that this is a "theoretical question" coming from my doubt about the physics behind the initial scenario shown
As you have been told a number of times
There is an incomplete circuit, therefore NO CURRENT FLOWS
Repeating the same erroneous Q over and over isn't going to get a different result.
I see that, but try to consider the following point of view: if the whatsoever initial potential of the electrode respect to Earth has to drop to the Earth potential (let's assume 0V) upon connecting the voltmeter to the ground, a rearrangement of charges on the electrode has to take place I guess...does not that imply a flow of charges (electrons) somehow ?
Why do you think it has to drop ??
I don't see any reason why it should
You have to stop guessing. Do the experiment, see what happensNo complete circuit ... No current flows
That would only happen with a static electric charge ...
eg
You walk across the carpet and you accumulate charge on your body
You touch the metal door knob and get a shock as the accumulated charge returns to where it
came from
Tho you may think it's just a one way circuit because you don't consider the accumulation of charge
as you walk, never-the-less that is part one of the circuit in action
Part two comes into action when you discharge as you touch the door knob ... the circuit is completedEven tho it is after sunset here and I know what the result will be, I'm going to do the experiment
using the 12V car battery ... If it was daylight, I would video the results for you... maybe another day
I'm really starting to wonder if you have this static discharge and charge redistribution stuck
in your mind and you
somehow think it also applies to any situation including a battery ( DC) situation ?
Your continued non-acceptance of the physics, as has been presented, suggests such ??Dave
