Understanding Electric Potential and Energy: Tips for Physics 12 Students
Electric potential and energy in physics involve understanding the relationship between voltage, charge, and work. The discussion clarifies that moving a charge in an electric field requires force, which varies with distance as 1/r^2, while potential energy can be simplified using the 1/r relationship. The work done in moving charges can be calculated through the integral of force over distance, linking the concepts of electric potential and energy. The confusion arises from the transition between these concepts and their mathematical representations. A deeper understanding will develop with time and practice, especially as calculus is introduced.
Alkatran
I'll start by apologizing for any incorrect terms. I've learned all of this in french so a few words may be misspelled or even misused.
We just started doing electricity in physics 12. I understand F = kqq/r^2 perfectly, I get that potential (electric?) energy is the same formula, multiplied by r. I can do the problems through guesswork (Well, if Voltage is J/C, and I have work and charge...) but I don't UNDERSTAND why I'm doing these things. It's like flying on autopilot.
Basicly what I have trouble understanding is:
Conversion from voltage to charge/work. Why does it work? It takes 1 Joule to move 1 C to the position that has 1 V electric potential right? What are the two different type of fields? (There's one that is /r^2 and one that is /r, what is each and how are they used?)
Just generally confused here. We have a quiz tomorrow and I don't want to have to do some fancy guesswork (even if it does always work).
Conversion from voltage to charge/work. Why does it work? It takes 1 Joule to move 1 C to the position that has 1 V electric potential right? What are the two different type of fields? (There's one that is /r^2 and one that is /r, what is each and how are they used?).
No, there's only one field it is like 1/r. The other is a force. It is like pushing a car up hill. At every point, a certain force is required. This force is proportional to the slope of the hill. But the field is related to the height you've moved the car to. When you are done, the work is the change in height, but you can find the same answer by multiplying the force needed at every point by the small distance traveled and adding all these contributions together. Guess what? You'll get the same answer.
So with charges. To move two charges closer together requires force which varies with distance as 1/r^2. The amount of work done, can however be calculated much more simply by comparing the potential energy of the particles (1/r) before and after they were moved.
In short, the work is the integral of F.dx, and when you integrate 1/r^2, you get -1/r. But I don't suppose you've learned any calculus yet. There's lots of fun in store for you!
I'm actually doing calculus now (and having an incredibly easy time, mind you.. hit into how to find a polynomials slope at any point by myself). I already knew of the similarities between the attraction between charges and gravity but my question is very vague.
I'll just think about it for a while and it'll sort itself out... I'll associate the names with the equations tomorrow..
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
