Electric Radiator: P=750W, V=230V, R=70.54 Ohms
  • Thread starter Thread starter chawki
    Electric Radiator
An electric radiator with a power output of 750 W and a voltage of 230 V has a resistance of 70.54 Ohms. When two such radiators are connected in parallel, the total heating power is 1500 W, while in series, it is 375 W. The discussion emphasizes that calculating power can be simplified by understanding that doubling the resistance halves the power, and vice versa. Participants suggest using dimensional analysis to avoid unnecessary calculations involving resistance. The conversation highlights the importance of efficiency in problem-solving during exams.
chawki
An electric radiator which is an ordinary constant resistor emits a heating power of
750 W at a mains supply voltage of 230 V.
What is the total heating power in each respective instance when two such radiators are connected a) in parallel, and b) in series to the 230 V
supply voltage?
P=750 W
V=230 V
we calculate R
P=V2/R
R=2302/750
R=70.54 Ohms
when 2R are in parallel:
Req=R/2 = 70.54/2 = 35.27 Ohms
P=2302/35.27 = 1499.85 approximately 1500 W
when 2R are in series:
Req=2R
P=2302/(2*70.54)
P=375 watt
hi chawki! :smile:
yes, that's correct :smile:
except
chawki said:
… P=2302/35.27 = 1499.85 approximately 1500 W
it isn't approximately 1500 W, it's exactly 1500 W :wink:
it's time you learned how to do this without finding R
P = V2/R, and you know that the new resistance is either R/2 or 2R, so the new power will be either twice or half the original power, ie 750*2 W or 750/2 W, ie 1500 W or 375 W exactly :wink:
isn't that easier, and less likely to lead to errors? :smile:
you are very right, but i couldn't understand the tip
and I'm used to use R
i tried I but it didn't help a lot..always that small error, but well, in my answer using R i just round it to 1500 :biggrin:
it should be ok ?
chawki said:
it should be ok ?
yes, but it takes up time in the exam …
the principle is very easy …
you know the formula is P = V2/R …
if you're only changing R, then obviously if you multiply R by 2, you'll divide P by 2
(alternatively, if you keep R the same, and multiply V by 2, then you'll multiply P by 4)
you don't need to know R (or in the second case, V) to do it! :smile:
some courses call this "dimensional analysis"
so R will goes away?
can you write that step by step and i will understand it
yes :smile:
P1 = V2/R1
P2 = V2/R2
So P2/P1 = R1/R2 :wink:
