Calculating Force on Potassium Ion Due to Electric Field
To calculate the force on a potassium ion (K+) due to an electric field from charges on a cell wall, use the formula F = qE, where q is the charge of the ion and E is the electric field. The electric field can be determined using E = kq/r^2, with k as Coulomb's constant and r as the distance from the charge. For distances of 2.70, 2.92, and 4.00 micro-meters from the center of the cell, convert these to meters before calculations. The total charge on the cell wall is 1.00 x 10^-15 C, and the charge of the potassium ion is 1.60 x 10^-19 C. Following these steps will allow for the calculation of the force at each specified distance.
thebigbluedeamon
If someone could help me start this problem, it would be greatly appreciated.
Charges of equal magnitude 1.00X10^-15 C and opposite sign are distributed over the inner and outer surfaces of the cell wall. Find the force on the potassium ion (K+) if the ion is, (a) 2.70 micro-meters from the center of the cell, (b) 2.92 micro-meters from the center, and (c) 4.00 micro-meters from the center.
I suspect that I'm going to use F=qE but I'm not quite sure.
What size are the inner and outter surfaces of the cell wall? Are the charges distributed uniformly?
I guess that you have to calculate the electric field, but the electric field depends on the cell wall.
Sure, I can help you get started on this problem. First, let's review the formula for electric force, which is F = qE. Here, q represents the charge of the particle and E represents the electric field. In this problem, we are looking for the force on a potassium ion (K+) due to the electric field created by the charges on the cell wall.
To solve this problem, we will need to calculate the electric field at each distance from the center of the cell. The electric field created by a point charge can be calculated using the formula E = kq/r^2, where k is the Coulomb's constant (8.99 x 10^9 Nm^2/C^2), q is the charge of the point charge, and r is the distance from the point charge.
For part (a), the potassium ion is 2.70 micro-meters from the center of the cell. First, we need to convert this distance to meters, which is 2.70 x 10^-6 m. Then, we can calculate the electric field at this distance by using the formula E = kq/r^2, where q is the total charge on the cell wall (1.00 x 10^-15 C) and r is the distance from the center (2.70 x 10^-6 m). This will give us the magnitude of the electric field at this distance.
Once we have the electric field, we can use the formula F = qE to calculate the force on the potassium ion. Remember, q represents the charge of the particle, which is the charge of the potassium ion (1.60 x 10^-19 C). So, the force on the potassium ion at this distance would be F = (1.60 x 10^-19 C)(electric field at 2.70 x 10^-6 m).
You can follow the same steps for parts (b) and (c), using the respective distances and calculating the electric field at each distance. Just remember to convert all distances to meters before plugging them into the formulas. I hope this helps you get started on the problem. Good luck!
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
