Electriccal charges and vectors
  • Thread starter Thread starter Rave Grrl
    Charges Vectors
The discussion focuses on calculating the horizontal and vertical components of the electrostatic force on a charge in a square configuration. The user initially calculated the horizontal component as 0.0013081 N and the vertical component as 4.321 N, but both were incorrect. There is confusion regarding the contributions from the charges, particularly the influence of the +2q and -2q charges. The user suggests that their calculations may be off by a factor of two and seeks clarification on the correct approach to account for the charges. The conversation highlights the need for clear equations to identify errors in the calculations.
Rave Grrl
Code:
+q    -a-    -q
a            a
+2q   -a-  -2q
What are the horizontal and vertical components of the resultant electrostatic force on the charge in the lower left corner of the square if q = 0.9 10-7 C and a = 4.4 cm? (Assume the positive directions are upward and to the right.)
For the horizontal component I got .0013081 N and for the Vertical I got 4.321 N, but neither one is correct.
I found the charge between +2q and -2q, and then I added the charge from +2q to -q times cos(45). That should have given me the horizontal charge but it didn't. What am I doing wrong?
your answer for the horizontal component is a factor of 2 off (that is my answer is twice the value of your answer), did you account for the 2q?
edit: if show your equations we can see exactly where an error occured
If your answer is .0026162 N that isn't correct either. I don't really know how to show the calculations here though.
The exact answer I got was .026626077 N, which is assuming that the positive direction is to the right. What does the book say the correct answer is?
