Electricity Help: 25 Ah Battery & 8 kW Shower Heater
  • Thread starter Thread starter CathyLou
    Electricity
To determine the number of available electrons in a 25 Ah battery, one must convert the battery's capacity from Amp Hours to Coulombs by multiplying 25 Ah by 3600 seconds. The total charge can then be calculated, and dividing this by the charge of an electron (1.6 x 10^-19 Coulombs) will yield the number of electrons. For the 8 kW shower heater operating at 240 V for 5 minutes, the total energy consumed can be calculated using power and time, and the number of electrons can be derived similarly. Understanding the relationship between charge, current, and time is crucial for these calculations. Proper conversion and application of formulas are essential for accurate results.
CathyLou
Hiya.
I'm really struggling with the following electricity questions and so any help would be very much appreciated.
How many available electrons are there in a 25 Ah battery?
How many electrons pass through a 240 V mains shower heater of 8 kW if it is on for 5 minutes?
Thank you.
Cathy
You have to find the charge moving/transferring in each case first then convert this knowing the charge on an electron.
So, you need the formula that links charge, current and time (and watch out, your battery is given in Amps Hours and you'll need it in seconds)
Thanks for replying.
To convert the battery from Amp Hours to seconds, do I just divide 25 by 60?
I know that I = Q / t and that the charge on an electron is 1.6 x 10^-1, but I'm still not sure how to get an answer to the first question.
Cathy
No, I think you'd multiply by 60x60.
I think 25Ah means it can give 25 amps for 1 hour (or 1 amp for 25 hours or any number of other combinations) so it will give 25 amps for 60x60 seconds.
That will give you the total charge available - and since you know the charge on each electron, just divide by that to find out how many electrons.
Okay. Thanks for your help!
