Electromagnet & Magnetic field range in milliseconds?
Building an electromagnet capable of generating a magnetic field of 1 to 5 Tesla in milliseconds poses challenges due to high resistance and inductance, typically resulting in field generation times of 2 to 5 seconds. While it is theoretically possible to create a faster electromagnet, it would likely be weaker and require significant power, around 15 to 20 kW, along with cooling solutions such as water or air. The design must consider coil size and the number of turns, as larger coils require more current, generating additional heat and necessitating effective heat dissipation methods. Air cooling or heat sinks could potentially reduce the cooling burden compared to water. Overall, achieving a strong, rapid electromagnet requires careful balance between power, cooling, and design efficiency.
PhiowPhi
How is it possible to build an electromagnet(magnetic field of 1 - 5 Tesla) that could create the magnetic field in milliseconds or less? Electromagnet designs that I found would have high resistance & inductance, creating a field in 2 - 5 seconds. Although, they would consume 15 - 20kW of power.
And would require 1 liter of water/min for cooling, can an electromagnet be built without having all that cooling?
yes, but it just wouldn't be as strong
Would it be possible to build such an electromagnet? And that fast...? Why would it be weaker?
I find using water for cooling is going to be a bit tedious, can't air cooling be used? Or heat sink transferring?
for a high power electro magnet
the coil must be larger ( more turns etc) -- this affects the rise time of the of the magnetic field
The larger the coil and the stronger the magnetic field, the more current that is required and that is going to generate lots of heat
thus better types of heat dissipation needs to be considered
Wouldn't more turns means the time would be slower?
Having heat reduced can be solved possibly with air(fans) or maybe similar to the idea of heat sinks, what about the power required for such a magnet?
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
