Electromagnetic decay inside materials.
The discussion focuses on the relationship between electromagnetic wave decay inside materials and the appearance of metal surfaces. The derived formula describes how electromagnetic waves propagate and decay within a material, with skin depth being a key factor influenced by conductivity. Higher conductivity materials tend to have larger skin depths, which may correlate with a shinier appearance due to increased reflectivity. However, the connection between wave decay and surface appearance is complex and not directly proportional. Ultimately, while higher conductivity can lead to a shinier surface, other factors like surface smoothness also play a significant role.
Squires
Hey guys, back again for some help if that's okay!
I've derived a formula for an electromagnetic wave entering a material, as \underline{E}e^{-\frac{x}{\delta}}e^{i(\frac{x}{\delta}- \omega t)}
x=direction of propagation
t=time
\delta=skin depth
As you can see this describes the wave propagating into the x direction, but also decaying.
My question asks to relate this decay inside a metal to the appearance of the metal surface, when the metal is smooth.
My attempt at this solution is that the decay will be greater, as the skin depth is larger.
Then the skin depth increases as the conductivity of the material decreases.
But then I'm stumped. I looked online for things such as, are higher conducting materials shinier than lower conducting materials? Or is this just too vague of an approach would you think? And is it even correct?
Any help would be much appreciated!It's difficult to directly relate the decay of an electromagnetic wave to the appearance of a metal surface. The skin depth is related to the conductivity of the material, but not necessarily the appearance. However, there are some indirect relationships that you can consider. For example, higher conductivity materials may be more reflective, and thus appear shinier than lower conductivity materials. It's also possible that higher conductivity materials may have a smoother surface structure which can increase reflectivity and make them appear shinier.
(a) The polarisation pattern is elliptical with maximum (1,1) and minimum (-1,-1), and anticlockwise in direction. (b) I know the solution is a quarter-wave plate oriented π/4, and half-wave plate at π/16, but don't understand how to reach there. I've obtained the polarisation vector (cos π/8, isin π/8) so far. I can't find much online guidance or textbook material working through this topic, so I'd appreciate any help I can get. Also, if anyone could let me know where I can get more...
  • · Replies 36 ·
