Electromagnetic Force problem
In summary, the problem involves a rotating disk made of metal with conductivity g and thickness t, placed between the poles of a magnet producing a uniform magnetic field B over a small square area of size a^2. The goal is to calculate the approximate torque on the disk, with the assumption that the resistance of the eddy current circuit is known. However, the effective electric field inside the conducting disk is not simply given by V x B, as there are additional contributions from the buildup of electric charge. An alternative approach could be to estimate the induced emf and the total resistance of the circuit, and use the electric power to determine the torque.
facenian
436
25
A circular disk rotates about its axis with angular velocity ##\omega##. The disk is made of metal with
conductivity g, and its thickness is t. The rotating disk is placed between the pole' faces of a magnet
which produces a uniform magnetic field B over a small square area of size a^2 at the average distance r from the axis; B is perpendicular to the disk. Calculate the approximate torque on the disk.
(Make a reasonable assumption about the resistance of the "eddy current circuit. ").
Force density=##\vec{J}\wedge\vec{B}##
Current density is given by Ohm's law: ##\vec{J}=g\vec{E}##, where g is the conductivity
In our case ##\vec{J}=g\vec{V}\wedge\vec{B}=gVB\hat{a}_r##, where ##\hat{a}_r## is the radial unit vector of a cilyndrical coordenate system and ##\vec{V}\wedge\vec{B}## is equivalent electri field
The total force is
$$\int\vec{J}\wedge\vec{B}\,dr^3=\int gVB\,\hat{a}_r\wedge B\,\hat{k}\,dr^3=\int gVB^2(-\hat{a}_\theta)\,dr^3\approx -gVB^2\hat{a}_\theta\int dr^3=-gVB^2 a^2 t \hat{a}_\theta $$
putting ##V=\omega r## the torque of this force is:
$$-g\omega r^2 B^2 a^2 t \,\hat{a}_\theta $$This is a problem from Electromagnetic Theory of Reitz-Milford-Christy and the answer given in the book is
$$-\frac{1}{2}g\omega r^2 B^2 a^2 t \,\hat{a}_\theta $$
I don't know where the factor ##\frac{1}{2}## comes from
I suspect that the effective electric field inside the square patch is not given by just ##\vec{V}\wedge\vec{B}##. There will be additional electric field contributions from the buildup of electric charge at various places in the conducting disk. It would be very complicated to calculate these effects directly. In circuits, we generally "work backwards" to find the electric field inside the conductors. Knowing the applied voltage in a simple circuit and knowing the total resistance, you can determine the current (and hence the current density in the wires). Then from J = gE you can deduce the electric field in the wires. The electric field inside the conducting wires is due not just to the source of emf but also to charges that build up along the wires in the circuit. Likewise, in your problem, the effective E field is related to the current density which in turn is determined by the effective emf and net resistance of the eddy current circuit. I hope this is making some sense.
As a simple illustration, consider the example of a DC generator where a rod is moved through a B field to generate a motional emf. See picture attached below. The induced emf ε and the total resistance in the circuit determine the induced current. You can then use the dimensions of the rod to determine the current density in the rod. This current density is then related to the effective E field inside the rod via J = gE. This effective E field will not be equal to ##\vec{V}\wedge\vec{B}##.
You might try a different approach. Estimate the induced emf due to the motion of the disk through the B field. Then estimate the total resistance of the eddy current circuit. I believe this estimation of the total resistance is what the problem is referring to when it says, Make a reasonable assumption about the resistance of the "eddy current circuit. " (This can only be a rough estimate and therefore will not necessarily lead to exactly the factor of 1/2 that you are looking for in the final answer.)
Once you have an estimate of the resistance, you can calculate the electric power generated. Can you use the electric power to determine the torque?
Likes facenian
1. What is the electromagnetic force problem?
The electromagnetic force problem refers to the difficulty in reconciling the theories of electromagnetism and gravity, as they seem to be incompatible at the quantum level.
2. Why is the electromagnetic force important?
The electromagnetic force is one of the four fundamental forces of nature, responsible for holding atoms and molecules together, creating electric and magnetic fields, and powering most of our everyday technology.
3. How is the electromagnetic force related to electromagnetism?
Electromagnetism is the branch of physics that studies the electromagnetic force, which is generated by the interactions of electrically charged particles. Electromagnetism also encompasses the study of electric and magnetic fields.
4. What are the challenges in understanding the electromagnetic force?
One of the main challenges in understanding the electromagnetic force is its dual nature as both a wave and a particle. This duality is described by quantum mechanics but is still not fully understood. Additionally, the interaction between electromagnetism and gravity remains a mystery.
5. How are scientists working to solve the electromagnetic force problem?
Scientists are conducting experiments at high-energy particle colliders, such as the Large Hadron Collider, to study the behavior of particles and their interactions. They are also developing new theories and mathematical models to try and reconcile the conflicting theories of electromagnetism and gravity.
