Electromagnetic induction and conductor
The discussion revolves around the phenomenon of electromagnetic induction, specifically addressing whether an electromotive force (EMF) is induced in a conductor moving through a uniform magnetic field. The scope includes theoretical considerations based on Faraday's law and the conditions under which EMF can be generated.
  • One participant questions the necessity of a change in magnetic flux for EMF induction, suggesting that if the magnetic field is uniform, there should be no induced EMF.
  • Another participant counters that if the conductor has a component of motion perpendicular to both the magnetic field and its velocity, EMF can still be induced.
  • A third participant references the formula F=qvB sin(theta), indicating that the motion of electrons in the wire will result in current flow, emphasizing the importance of the perpendicular component of the magnetic field.
Participants express differing views on the conditions required for EMF induction in a moving conductor within a uniform magnetic field. The discussion remains unresolved regarding the implications of uniform magnetic fields on EMF generation.
The discussion highlights potential limitations in understanding the relationship between magnetic flux and induced EMF, particularly regarding the role of the conductor's motion and the orientation of the magnetic field.
ViolentCorpse
Hello everyone,
One very basic thing about this phenomenon is not very clear to me. If a conductor moves in a region of uniform magnetic field, would it have an EMF induced across it? I'm confused because as per Faraday's law, a change in flux through the conductor is necessary for EMF to be induced in it but if the flux is everywhere the same in the region where the conductor is moving, there should be no change in flux through it and consequently, no EMF in it.
How much wrong am I?
If it has a component perpendicular to both motion and magnetic field, yes.
Think of an imaginary loop, with the moving conductor and some stationary part, completing the loop (and some hand-waving to maintain the connection). The flux through this loop will change.
Remember the F=qvB sin (theta) formula... The electrons in the wire will be pushed by the m field resulting in current flowing the opposite direction... As mfb said,there only has to a component of the m field perpendicular to the velocity...
I see.
Thank you!
  • · Replies 16 ·
