Electromagnetism: charge density
The discussion revolves around finding the volumetric charge density function, p, for a sphere with a constant electric field, E, inside it. The user attempts to derive p using the divergence of the electric field and Gauss's law but encounters difficulties, particularly in integrating p as it is a function of the radius. They derive two expressions for p, ultimately realizing that the expected result is p = 2*E*ε/r, which differs from their calculations. Additional insights suggest that the electric field at the center of the sphere is zero, complicating the analysis. The conversation highlights the challenges in applying theoretical equations to practical problems in electromagnetism.
Jalo
Given a sphere of radius R with a volumic charge distribution p find the function p.
The electric field inside of the sphere is radial with a constant modulus E
div E = p / ε
∫∫E.ds = 1/ε * ∫∫∫ p * dV
I tried to solve it using those two equations. (r is the radius)
div E = p / ε ⇔ dE/dr = p/ε ⇔ ∫dE = 1/ε ∫p dr ⇔ E = 1/ε * p * r ⇔
⇔ p = E*ε / r
I don't think I can integrate p like that, since p is a function of the radius. I don't know what to do thought..
Using the second equation and solving in a similar way I get:
∫∫E.ds = 1/ε * ∫∫∫ p * dV ⇔ E*4*pi*r^2 = 1/ε * p * (4/3)*pi*r^3 ⇔
⇔ p = 3*E*ε/rThe correct result would have been p = 2*E*ε / r
Any help would be appreciated!
Thanks.
Daniel
div E = p / ε
⇔ p = E*ε / r
⇔ p = 3*E*ε/r
Thanks.
Daniel
they usually tell the function of (ρ) rho, volume charge dis... and find the totale charge... use the equation Q = ∫∫∫ρdv , dv is easy to find even they don't tell... but they not even tell the function of Q ! if they did , may be use dQ/dv=ρ.
And the electric field to the center of the sphere is 0 , no matter of volume charge dis.. or surface charge dist... if the electric field to other point than center , it's much more complex... use the equation dE = kρdv/r^2 , k=1/4∏ε =contante
so Ez =∫∫∫dE cosθ =0
Ey=∫∫∫dE cosθcosα =0
Ex=∫∫∫dE cosθsinα =0
so E =0 to the center of sphere...
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
