Electron shot between plates (electric field)
The discussion revolves around solving a physics problem involving an electron shot between two charged plates in a uniform electric field. The key points include understanding that the electric field exerts a force on the electron, which can be calculated using F = Eq, where E is the electric field strength and q is the charge of the electron. The problem requires breaking down the initial velocity into horizontal and vertical components, as only the vertical motion is influenced by the electric field. Participants emphasize the importance of applying concepts from both electricity and projectile motion to determine whether the electron will strike a plate and where. The explanation clarifies the approach needed to tackle the problem effectively.
miroku2192
I've been staring at this last problem for a while now...but i really don't get it. So if someone could explain to me how to do this, that'd be great. Thanks:
In Fig. 22-64, a uniform upward electric field E of magnitude 2.00 x 10^3 N/C has been set up between two horizontal plates by charging the lower plate positively and the upper plate negatively. The plates have length L = 10.0 cm and separation d - 2.00 cm. An electron is then shot between the plates from the left edge of the lower plate. The initial velocity of V(sub zero) of the electron makes an angle theta =45.0 degrees with the lower plate and has a magnitude of 6.00 x 10^6 m/s.
(a) will the electron strike one of the plates? (b) If so, which plate and how far horizontally from the left edge will the electron strike?
I'm really confused on this...so if someone could help that'd be great. I was never really good at physics.
Relevant equations? There were none provided..?
Can someone just point me in the right direction first? I'm a bit confused on how I'm supposed to go about even TACKLING the problem. Would i use the E= kQ/r^2 ? Since it's only one electron being acted on by the electric field? So it's like a point electric field thing?
No, that's the field produced by a point charge. You already know the field. You must find the force that the given field exerts on the electron. (What's the relationship between F, E, and q?)
Ohh...i see, so it's like a mix of electricity + projectile motions right? Because... F= Eq, and E is given, and q i know because it's the same for both protons + electrons right? something like -1.6 x 10^-19? Anyway, after i find the force in Newtons, i can just set it up as F = mass x acceleration, figure out acceleration and use projectile motions stuff right? I'm a bit shakey on projectile motions stuff though...when it says "a magnitude of 6.00 x 10^6 m/s.", does that mean after i find out acceleration, the initial velocity value i use is 6.00 x 10^6 m/s ?
Exactly right.
Yes, but realize that the initial velocity is at an angle, so you need to find horizontal and vertical components. Only the vertical component of motion is accelerated--just like with regular projectile motion.
Doc Al said:
Exactly right.
Oh right...i have to split up the x components and y components...Thanks so much, i think i get this question now. I really appreciate ALL your help!
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
