Electrostatic force on a parallel plate
To find the force between parallel plates in a capacitor, the formula F=qE is not sufficient due to the need to account for the electric field's characteristics. The electric field E is typically derived from the charge density and is halved when considering the contribution from both plates. The discussion suggests using Coulomb's law or calculating the electric field from a single sheet of charge for clarity. There is confusion regarding the correct value of the electric field, indicating a need for a deeper understanding of the underlying principles. Accurate calculations are essential for determining the force exerted between the plates.
serverxeon
I'm tasked to find the force one parallel plate exert on the other plate in a capacitor.
somehow the force isn't just F=qE, where E=Q/2εA
What am I missing here?
Erm - direction?
You can check by using another method ... i.e. Coulombs law for a point charge and add them up, or start with the electric field due to a sheet of charge by itself.
i mean, my solution is lacking so coefficient.
based on my (confused and vague) understanding, the electric field is actually 1/2 E or something?
Is it? Why not calculate the field?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
