Can a charged sheet attract uncharged objects?
  • Thread starter Thread starter utkarshakash
    Electrostatics
A charged conducting sheet can attract uncharged objects through the process of electrostatic induction. When a positively charged sheet is near uncharged metal rods, it induces a negative charge on the side of the rods closest to the sheet, while the far side becomes positively charged. This creates an attractive force between the sheet and the rods, allowing the charged sheet to attract them. Additionally, the induced charges on one rod can further influence the other rod, leading to mutual attraction. The discussion emphasizes the role of electrostatic induction in explaining these interactions.
utkarshakash
A large conducting sheet M is given a uniform charge density. Two uncharged small metal rods A and B are placed near the sheet on one side. Then
a)M attracts A
b)M attracts B
c)A attracts B
d)B attracts A
An electric field will be set up by the sheet but A and B are neutral. So how can it attract them?
Good Morning Utkarshakash,
Have a look at "electrostatic induction".
J.
J.
OK so if I assume the sheet to be +vely charged it will induce a -ve charge on the side of block A near to the sheet and +ve charge on the other end. Block A will then induce -ve charge on the side of B near to A and +ve charge to the other side. Am I right?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
