Electrostatics-Taylor expansion
  • Thread starter Thread starter penguin007
    Expansion
penguin007
Hi everyone
First, I’m sorry if this topic is not in the right place here (I did hesitate with introductory physics).
My questions are the following:
In a Cartesian coordinate system:
Consider that you have four charges q placed in (a,0,0);(-a,0,0);(0,a,0);(0,-a,0).
The electrostatic field in O(0,0,0) will be null(because of the symmetries). But what is the form of the Taylor expansion of the potential near the origin O?
The answer is V(M)=V0+b*x+c*y+d*z+e*x^2+f*y^2+g*z^2+h*x*y+i*x*z+j*y*z
But I can’t understand WHY?
Second question:
Consider the electrostatic field E(M)=(x,y,-2*z) (in a Cartesian coordinate system).
“If you put a particle of charge q in M, then if it’s movement is stable in xOy, then this movement won’t be stable in (Oz)” Again, I can’t understand why.
Any help would be welcome!
Hi penguin007, you've been here long enough that you should know you need to show some attempt at a solution, or at least explain where you are stuck!
What is the expression for the potential due to a collection of point charges?
Second question:
Read the section of your textbbook on Earnshaw's theorem.
Hi, gabbagabbahey, sorry if my questions were not clear...
actually I guessed that I had to do a Taylor expansion at the order 2 to get the first result but didn't know its expression (I got it:https://www.physicsforums.com/showthread.php?t=346001).
For my second question, I understand it is linked to Earnshaw's theorem, but I still don't get the idea:how can this field be stable in xoy and not in (oz)? Any explanation would be welcome...
Well, Earnshaw's theorem tells you it can't be stable in three dimensions...If its stable in two dimensions, it must therefor be unstable in the third dimension.
Therefore, it could also be stabe in (xoz) and not in (oy)?
Yes.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
