Elementary Boltzmann Statistics
The discussion revolves around calculating the proportion of particles in the ground state of a system at equilibrium using Boltzmann statistics. The participant correctly identifies the partition function for a single particle as Z1 = 1 + exp(-εs/τ) + exp(-2εs/τ). There is some confusion regarding the partition function for N particles, with clarification that it is not simply Z1 raised to the power of N, but rather involves the grand canonical partition function. The distinction between single and multiple particle partition functions is emphasized, particularly in the context of non-interacting particles. The conversation concludes with a reference to Kittel & Kroemer, highlighting the importance of understanding these partition functions in statistical mechanics.
Phyisab****
***SOLVED***
A system of particles is at equilibrium. What is the proportion of particles in the ground state?
P(\epsilon_{s})=\frac{exp(-0/\tau)}{1+exp(\frac{-\epsilon_{s}}{\tau})+exp(\frac{-2\epsilon_{s}}{\tau})}
Is that right? This is a really basic problem but I haven't dealt with this in a while. Thanks!
Seems right to me.
So what threw me for a little bit of a loop about this was that the denominator of the equation I posted is the partition function.
<br /> Z_{1}= 1+exp(\frac{-\epsilon_{s}}{\tau})+exp(\frac{-2\epsilon_{s}}{\tau})<br />
Then later I am asked what the partition function is. I guess the point is that Z above is the partition function for a single particle, not the whole system which would be
Z_{1}^{N}
does that seem right? Edit: The particles are not indistinguishable.
I don't quite understand what you're saying. The partition function is exactly what you posted. You seem to think that there's another partition function for the whole system, which isn't the case.
Well then we are both confused :). I am asked
1. what is the partition function of a single particle?
2. what is the partition function for N particles?
Thanks for your time I really appreciate it.
Edit: Quoting Kittel & Kroemer, "If we have one atom in each of N distinct boxes (which is equivalent to N in one box, because they are non-interacting I assume), the partition function is the product of the separate one atom partion functions." Thanks for your help again.
So in other words for N particles we are talking about the grand canonical partition function.
