Elementary ODEs matrix integration help
EngageEngage
I'm trying to understand the Variation of Parameters in ODEs and I came up to this following expression which i cannot solve:
{2\,{e}^{-t}{e}^{-3\,t}\choose {e}^{-t}{e}^{-3\,t}} \int {\,{e}^{t} {e}^{\,t}\choose {e}^{3t}{2e}^{-3\,t}} {10\,\cos \left( t \right) \choose 2\,{e}^{-t}}
Can I just integrate each individual component or must I use matrix multiplication first? If anyone could help me I would appreciate it greatly. I'm not sure how to even start on this so I don't have any work to show.
It's not at all clear what those mean. Do you mean
\left(\begin{array}{cc}2e^{-t} & e^{-3t} \\ e^{-t} & e^{-3t}\end{array}\right)\int \left(\begin{array}{cc}e^t & e^t \\ e^{3t} & 2e^{-3t}\end{array}\right)\left(\begin{array}{cc}10 & cos(t) \\ 2 & e^{-t}\end{array}\right) dt
(Click on the LaTex to see the code I used.)
To answer your question, yes, you must multiply before integrating: \int f(x)g(x) dx is NOT (\int f(x)dx)(\int g(x)dx).
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
