Solve Elevator Problem with Weight & Acceleration on Moon
  • Thread starter Thread starter seizureboi
    Elevator
The discussion focuses on calculating the apparent weight of a 65kg astronaut in a moon elevator under different conditions. For part (a), the astronaut's apparent weight when the elevator accelerates upward at 5 m/s² is calculated to be 219N. In part (b), to achieve an apparent weight of 500N, the required acceleration of the elevator is determined to be 9.32 m/s². A correction is noted regarding the direction of forces, emphasizing that the apparent weight and true weight must act in opposite directions. The calculations are confirmed to be correct with this understanding of force dynamics.
seizureboi
The effect of gravity is approximately 1/6 of what it is on Earth. If one were to build an elevator on the moon, (a) what would be the apparent weight of a 65kg astronaut when the elevator accelerates upward at 5 m/s2? (b) What is the acceleration of the elevator if the apparent weight of the astronaut is 500N?
F = ma
m = mass
m = 65 kg
w = weight
w = mg
a = acceleration
a = 5 m/s2
gM = 1.63 m/s2
The equation I set up for (a) was: ma - mg = w
OR (65)(5) - (65)(1.63) = w
OR 325 - 106 = w
Finally, w = 219N
For (b) I had the same exact forumla: ma - mg = w
OR (65)a - (65)(1.63) = 500
OR 65a - 105.95 = 500
OR 65a = 605.95
Finally, a = 9.32 m/s2
Just wondering, again, if this is right or not. =)
F = ma
m = mass
m = 65 kg
w = weight
w = mg
a = acceleration
a = 5 m/s2
gM = 1.63 m/s2
OR 325 - 106 = w
Finally, w = 219N
OR 65a = 605.95
Ouch, you let the plus and minus sign bite you. The acceleration is always in the direction of the net force. The apparent weight (the normal force) and the true weight must act in opposite directions.
