Ellipse Equation w/ only vertices and focus
  • Thread starter Thread starter kitgk
    Ellipse Focus
The ellipse has vertices at (2,3) and (-4,3) with a focus at (1,3), indicating a horizontal orientation. The center of the ellipse is calculated as (-1,3), and the distance from the center to the vertices gives a² = 9. The equation format is established as (x+1)²/b² + (y-3)²/9 = 1, but it requires an adjustment to include an equals sign on the right side. The relationship between a, b, and c for the ellipse needs to be used to determine the value of b. The final equation must be correctly formatted for clarity and accuracy.
kitgk
Ellipse with vertex at (2,3) and (-4,3) and focus at (1,3)
(x-h)2/a2 + (y-k)2/b2=1
(h,k)= (-1,3)
a2=9
(x+1)2/ b2 + (y-3)2/ 92
You have h and k correct. What is the equation relating a, b, and c for an ellipse? Use it to figure out b. And your final equation needs and = sign and a right hand side.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
