Ellipse perpendicular distance
Rikendogenz
Prove that the straight line x cos @ + y sin @ = p is a tangent to the ellipse x2/a2 + y2/b2 if a2 cos2@ + b2 sin2@ =p2 .
u and v are the perpendicular distances of a tangent from the two points M(0,ae) and N(0,-ae) respectively. Prove that u2 + v2 is a constant.
2. The attempt at a solution
So far I have: xx1/a2+yy1/b2 -1 = x cos@ + y sin@ - p
I don't know where to go from here and I know in the second part I have to use the perpendicular distance formula but I'm not sure what to sub in and why.
You mean the elliplse x^2/a^2+ y^2/b^2=1. You can simplify that a little by writing it as b^2x^2+ a^2y^2= a^2b^2. Differentiating with respect to x, 2b^2x+ 2a^2yy'= 0 so y'= -b^2x/a^2y. The tangent line at the point (x_1, y_1) is given by y= -(b^2x_1/a^2y_1)(x- x_1)+ y_1 or b^2x_1x+ a^2y_1y= b^2x_1^2+ a^2y_1^2[/tex].
If we are going to be able to write the coefficients as cos(\theta)[/itex] and sin(\theta), we must We must have cos^2(\theta)+ sin^2(\theta)= 1. Now we have b^4x_1^2+ a^4y_1^2 as the sum of the squares of the coefficients so divide the entire equation by the square root of that:<br /> \frac{b^2x_1}{\sqrt{b^4x_1^2+ a^4y_1^2}}x+ \frac{a^2y_1}{\sqrt{b^4x_1^2+ a^4y_1^2}}y= \frac{b^2x_1^2+ a^2y_1^2}{\sqrt{b^4x_1^2+ a^4y_1^2}}<br /> <br /> That is of the form cos(\theta)x+ sin(\theta)b= p
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
