EM Tensor & GR: Does Space Curvature Impact EM Field?
  • Thread starter Thread starter kroni
    Em Gr Tensor
kroni
Hello,
I am reading a book about General relativity, i understand that energy of the EM tensor go in the stress- energy tensor of GR equations. SO, EM field curve space. But i don't understand if space curvature impact EM field ? Is variation of space curvature can create EM field ?
Clément
kroni said:
Hello,
I am reading a book about General relativity, i understand that energy of the EM tensor go in the stress- energy tensor of GR equations. SO, EM field curve space. But i don't understand if space curvature impact EM field ? Is variation of space curvature can create EM field\?
No. The gravitational field is created by virtue of the EM field's energy density which has mass density. It's not the other way around though. I.e. just because something has something has mass density it doesn't mean that it has an EM field.
If i make no mistake, In yang mills theory, EM tensor is define as the connection in a fiber bundle with S1 Lie group, it seems logic to me that if base manifold has a changing curvature, the connection in the fiber bundle may change. So, space curvature might modify EM field. I will try to put this in equation to see where is my problem.
Yes spacetime curvature affects the EM fields present but that doesn't change what Mike said. You need a source of charges to generate the EM field in the first place for spacetime curvature to affect. See Einstein-Maxwell equations.
Yes, you are correct, the existence of space(time) curvature modifies the way the field looks like, simply because the PDE's for the field equations get extra terms, they are no longer the linear nicely-looking Maxwell Equations anymore. In the Y-M, we call them gauge potential (connection) and gauge field (curvature of the connection).
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
