The discussion revolves around the concepts of electromagnetic (EM) wave shielding and skin depth, particularly in the context of Faraday cages and the effectiveness of various materials at different frequencies. Participants explore the implications of skin depth on EM wave penetration and attenuation, as well as related calculations for electric field strength in proximity to antennas.
- Technical explanation
- Conceptual clarification
- Debate/contested
- Mathematical reasoning
- One participant questions whether the skin depth can increase beyond its defined value of 5mm when subjected to higher voltages of EM waves.
- Another participant explains that radiation does not stop abruptly at the skin depth, but rather tapers off exponentially, suggesting a gradual decrease in field strength.
- Some participants argue that with sufficiently high voltage, EM waves can penetrate any metal at any frequency, questioning the practical utility of the skin depth measurement.
- A participant clarifies that the skin depth indicates the depth at which the electric field falls to 1/e of its original value, and this pattern continues with additional layers of material.
- Discussion includes specific values for skin depth in aluminum at 100Hz, noting that the electric field drops by 1/e at approximately 8.2mm.
- Concerns are raised about the limitations of Faraday cages, including potential leaks through seams and ventilation holes, which can affect isolation performance.
- Participants discuss the attenuation of EM waves, noting a specific attenuation rate of 8.7dB for every skin depth below the surface.
- Questions arise regarding the calculation of electric field strength at a distance from a transmitter, with references to conservation of energy and power density decreasing as 1/r².
- A participant provides a formula for calculating electric field strength from a dipole antenna, noting that the behavior near the antenna differs from that at greater distances.
Participants express a range of views on the implications of skin depth and the effectiveness of shielding materials. There is no consensus on the maximum limits of skin depth or the practical implications of high voltage on EM wave penetration. The discussion remains unresolved regarding the utility of skin depth in practical applications.
Limitations include the dependence on specific frequencies and materials, as well as the need for precise definitions of terms like "absolute extinction" in the context of EM shielding.
