Embarassing question- Displacement equation
  • Thread starter Thread starter literacola
    Displacement
The original poster seeks to understand the displacement equation x = 1/2(v₀ + v)t, particularly questioning the origin of the 1/2 factor in relation to the simpler displacement equation x = vt.
  • Conceptual clarification, Mathematical reasoning
  • Participants discuss deriving the displacement equation from other kinematic equations and the relationship between average and instantaneous velocity. Some express confusion about the role of the 1/2 in the equation.
Participants are exploring different interpretations of the equations and their applicability under various conditions, such as constant velocity versus accelerated motion. Some guidance has been offered regarding the integration process and the concept of average velocity.
There is an emphasis on the distinction between average and instantaneous velocity, and the discussion includes considerations of constant acceleration. The original poster's question reflects a common point of confusion in kinematics.
literacola
Embarassing question-- Displacement equation
Im just trying to understand why the equation for displacement along a line is [tex]x= 1/2(v_{0}+v)t[/tex]. If the other equation for displacement is [tex]v*t[/tex], where does the 1/2 come from?
[tex]v*t[/tex]
Derive the formula you are asking about by using these other two kinematic equations
[tex]\Delta x = v_0t + \frac{1}{2}at^2[/tex]
[tex]v = v_0 + at[/tex]
Where does the 1/2 come from in the first equation you've given??
From integration needed to calculate displacement in uniformly accelerated linear motion.
you must take in consideration difference between Average velocity and Instantaneous velocity
x = vt v is average velocity
x= 1/2* (V0 + V )t now v is velocity at time t
Perhaps it's easy to see that the two equations are valid for different situations. Let's just consider the situation of a constant velocity v.
You will notice that if I have a constant velocity v, then the v0 the second equation: .5(v0+v)t is simply v (since velocity is constant, the initial velocity is equal to the velocity always). Therefore the second equation just reduces to: .5(v+v)t=vt the first equation!
Yeah, the equation x = vt is not accurate for an object with an acceleration. Perhaps that is why you are confused?
[tex]a = \frac{dv}{dt}[/tex]
[tex]a dt = dv[/tex]
[tex]\int a dt = \int dv[/tex]
[tex]at = v - v_0[/tex]
[tex]at + v_0 = \frac{dx}{dt}[/tex]
[tex]atdt + v_0dt = dx[/tex]
[tex]\int atdt + \int v_0dt = \int dx[/tex]
[tex] \Delta x = v_0t + \frac{1}{2}at^2 [/tex]
To simplify, the average of 2 speeds is 1/2 their sum!
This is of course true only when dealing with a constant acceleration, or that at least isn't a function of time.
Yes, but so is the original question.
  • · Replies 38 ·
  • · Replies 25 ·
