How Do You Calculate Induced Current in a Coil with Changing Magnetic Field?
  • Thread starter Thread starter phy112
    Emf Physics
To calculate the induced current in a coil with a changing magnetic field, first determine the electromotive force (emf) using Faraday's law of electromagnetic induction. The emf is calculated as E = -N(dΦ/dt), where N is the number of turns and dΦ/dt is the rate of change of magnetic flux. In this case, the magnetic field decreases from 1.8 T to 0 T over 4.3 seconds. The induced current can then be found using Ohm's law, I = E/R, where R is the resistance of the coil. Understanding the relationship between emf and current is essential for solving this problem.
phy112
The component of the external magnetic field along the central axis of a 50 turn coil of radius 4.7 cm decreases from 1.8 T to 0 T in 4.3 s.
If the resistance of the coil is 2.8 , what is the magnitude of the induced current in the coil?
E=50*(1.8T*pi*.047sqrd)/.43
I am confused on how you incorporate the resistance
The question asks you to find the induced current, not just the emf. How do you find current from emf?
