Emissivity as a function of wavelength
The discussion centers on the relationship between emissivity and wavelength, particularly in the context of a Leslie Cube experiment involving black and white painted surfaces. The user observed that both surfaces exhibited similar emissivities in the infrared spectrum despite their color differences, leading to the conclusion that color primarily affects visible light absorption and reflection, not thermal radiation emission. The user also recognized the importance of isolating reflected radiation from external sources to accurately measure emissivity.
  • Understanding of emissivity and its dependence on temperature and wavelength
  • Familiarity with thermal radiation concepts and blackbody radiation
  • Knowledge of the Leslie Cube experimental setup
  • Basic principles of light reflection and absorption
  • Research blackbody radiation and its role in thermal emissivity
  • Explore the principles of thermal radiation measurement techniques
  • Study the effects of surface color on emissivity across different wavelengths
  • Learn about isolating measurements in thermal experiments to avoid external interference
Students and educators in physics, materials scientists, and anyone conducting experiments related to thermal radiation and emissivity measurements.
yellowputty
Hello, I'm a little confused. I did an experiment today with a Leslie Cube. One of the faces was a black paint, and another a white paint. I know that white reflects well and has a low emissivity, at least in the visual wavelengths. In the Leslie's cube, was hot water, so I was measuring the Irradiance of thermal radiation. From the results I concluded that the white and black faces had similar emissivities (in fact the white face was slightly higher). I understand that emissivity depends on several factors, temperature, angle and also wavelength. How come in the infrared spectrum, both faces have similar emissivities? I have a feeling the answer lies in a blackbody diagram. Can someone point me in the right direction?
Thanks in advance :)
I think I just worked it out. Colour has nothing to do with a materials ability to absorb and hence emit thermal radiation. Colour is important in reflecting and absorbing wavelengths in the visible spectrum only. A white material will reflect all visible wavelengths, but a black surface would absorb all, and re-emit as thermal radiation.
I think oberlooked the way that visible light is then turned into thermal radiation. Thank you!
You may be correct. I thought of another problem. Maybe you are measuring reflected radiation that the cube reflects from external sources? How have you isolated this?
  • · Replies 23 ·
  • · Replies 29 ·
