Calculating Pump Power for Well Water Removal
  • Thread starter Thread starter Akash47
    Power Pump Work
To calculate the power of a pump for well water removal, one must determine the mean displacement of the center of gravity of the water being pumped. The well's volume is partially filled, and the pump can remove a specific volume in a set time. Understanding the mean displacement involves analyzing the center of mass of the water before and after pumping. Suggestions include using integration or breaking the water column into segments to simplify the calculations. A clear grasp of these concepts is essential for solving the problem effectively.
Akash47
A well has a diameter of 6 m and a height of 15 m.2/3 of volume of the well is filled with water.A pump can vacate 1/3 of volume of water from the well in 7 minutes 20 seconds.What is the power of the pump?
W=mgh, P=W/t
The question can be solved easily by using the given equations.But I don't know how I will find the mean displacement of center of gravity.Actually I don't have any idea about this (the part in bold line).So I want a clear concept about it.
Why don't you try making a sketch of where the water is before and after the pumping process?
I am sure that you haven't understand my problem clearly .I have already made a sketch of the problem but I haven't any idea about mean displacement of center of gravity.I just want a clear concept about this and nothing else.
Have you tried thinking about it using a simple integration, and then comparing that to the answer you get by using the center of the water column for the mean displacement? Or even simpler, you don't have to set up the integration, just consider different cases with different "pieces" of the water being taken out separately. Start with one whole piece with the center of mass in the center of the water column, and lift that center up to ground level. Then cut the column in half, and do the same for the two separate water columns and their centers of gravity. Then do the case cutting the water column into 4 pieces, and so on... :smile:
it means figuring out where the mass centre of the pumped water is before and after pumping and taking the vertical difference between the two.
Thanks.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
