Why Doesn't a Dropped Ball Bounce Back to Its Original Height?
  • Thread starter Thread starter B Cass
    Concept Energy
When a ball is dropped from a height, it does not bounce back to its original height due to energy loss during the collision with the ground. Some kinetic energy is converted into heat as the ball deforms upon impact, indicating an inelastic collision. If the collision were perfectly elastic, the ball would return to its original height without any energy loss. The change in shape during the impact is a key factor in this energy transformation. Thus, the ball's inability to reach the original height is a result of the energy lost to deformation and heat.
B Cass
"When a ball is dropped to the floor from a height h, it strikes the ground and briefly undergoes a change of shape before rebounding to a max ht. less than h. Explain why it does not return to the same height h."
Is this because some of the kinetic energy is transferred to heat?? What does the shape change have to do with it? I know I'm making this more complex than it has to be! TIA!
Yes, an amount of kinetic energy is transformed into heat caused by the deformation of the ball during the collision.
If the collision was perfectly elastic, it would bounce back to the same height, but KE is lost as you said. That "change of shape" line should get you thinking inelastic. Perfectly elastic means that it was at its original shape before and after the collision with no deforming whatsoever
