Sun Losing Mass due to Energy Radiation
The discussion focuses on calculating the mass loss of the sun due to energy radiation, given the solar constant of 1400 W/m² at Earth's distance. The initial approach involves using the formula Ei = E/r² to find the total energy output of the sun. To determine mass loss, the total energy output is then divided by c² using E=mc². The key point of confusion lies in calculating the total area over which the sun's energy spreads at Earth's distance. Understanding this area is crucial for accurately determining the sun's mass loss per second.
bon
Energy from the sun (distance 1.496 x 10^11m from earth) arrives at the Earth at a rate of 1400W/m^2. How fast is the sun losing mass due to energy radiation?
Ok so i thought that Ei = E/r^2 where Ei is incident radiation and E is radiation at source..
Therefore E sun = r^2 (1400)
Then using E=mc^2..I divide the result by c^2 to give mass loss per second..
but i don't get the right answer..where am i going wrong?
thanks
The solar constant specifies how much power sun light contains per square meter at our distance from the sun. To get the total power output of the sun light you would then need to know "how many" square meters there are all around the sun at our distance from it.
You are given the power per unit area at a certain distance from the sun. What's the total area over which the sun's energy is spread at that distance? (You're almost there.)
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
