Calculating Energy Released in a Fission Reaction: Where Did I Go Wrong?
The discussion revolves around calculating the energy released in a fission reaction, specifically involving U-235. The initial calculation mistakenly resulted in 1.15 x 10^12 J instead of the correct 1.15 x 10^9 J, indicating an error by a factor of 1000. Participants clarify that the mass should be in kilograms, not grams, and emphasize the importance of using Avogadro's number to determine the number of U-235 atoms per kilogram. The correct steps involve calculating the number of atoms in 2 kg of uranium fuel and converting the energy from MeV to Joules accurately. The final consensus suggests that the initial quoted answer may be incorrect, prompting further verification.
songoku
Calculate the amount of energy, in joules, generated from 2 kg of uranium fuel, if the U-235 represents 0.7% of the metal and every fission reaction produces 200 MeV.
E = mc^2
Energy = ##\frac{2000}{235}## x 6.02 x 1023 x 0.7% x 200 x 1 x 106 x 1.6 x 10-19 = 1.15 x 1012 J
But the answer is 1.15 x 109 J
I am off by a factor of 1000. Where is my mistake?
Thanks
SI units for mass is kg not g
Likes songoku
Sorry I don't understand the hint.
Wouldn't it be the same if I write: ##\frac{2}{0.235}## instead of ##\frac{2000}{235}##?
And I don't understand your solution, it is just a bunch of numbers.
Anyway, do it in steps. First, how many U-235 atoms are there per kg?
Likes songoku
Let me redo
1) No. of atoms of U-235 in 2 kg of uranium fuel = ##\frac{2000}{235}## x 6.02 x 1023 x 0.7% = 3.586 x 1022 atoms
2) Amount of energy released = 200 MeV x No. of atoms = 7.127 x 1024 MeV
3) Convert MeV to Joule = 7.127 x 1024 x 1 x 106 x 1.6 x 10-19 = 1.15 x 1012 J
Thanks
And 6.02 x 1023 is avogadros number, the number of entities in one mol.
U-235 is approx 235g / mol.
Anyway, the answer you quoted is most likely wrong.
Likes songoku
Thank you very much malawi_glenn
