Calculate Speed of Recoiling Hydrogen Atom After Transition to Ground State
  • Thread starter Thread starter the armed pacifist
    Energy Energy level
A hydrogen atom transitioning from the n = 4 state to the ground state emits a photon, leading to recoil. The energy difference calculated is 12.75 eV, and the mass to consider is that of a hydrogen atom, approximately equal to the mass of a proton. Conservation of momentum is crucial in this scenario, as the recoil speed can be determined using the emitted photon's energy. The problem can be solved without additional information by applying the principles of conservation of momentum and energy. Understanding these concepts is essential for calculating the speed of the recoiling hydrogen atom.
the armed pacifist
A hydrogen atom, initially at rest in the n = 4 quantum state, undergoes a transition to the ground state, emitting a photon in the process. What is the speed (in terms of m/s) of the recoiling hydrogen atom?
anyone knows what to do? i calculated the energy difference and got 12.75 eV and i calculated the potential energy as well, but i don't know which mass to assign the atom...
any help is appreciated...
(1) What's conserved during the emission?
(2) You can look up the mass of a hydrogen atom!
reply
well, that's the thing- the problem doesn't state anything more than I put on there... the mass of a hydrogen atom will be that of 1 proton, but I'm not sure if that's what i should look for...
any thoughts?
You don't need any more information to solve the problem. What's the answer to my first question? (Hint: In any kind of "explosion", what's conserved?)
